Denon AVR-3300 Receiver Logo
A
Anonymous Posted on Sep 24, 2011
I have connected the audio from 3 devices into the 3 optical inputs on my Denon AVR-3300. Audio for each device plays perfectly through main speakers but not through the multi-room output (which goes to amp and then speakers throughout the house). The multi-room is working fine for a 4th device that is connected to receiver via pin cord, so the amp and speakers are all functional too. I assume I set up optical inputs properly since the devices work fine on the main speakers. The "ext. in & multi" setting is set to "6CH In & Multi." I'm stumped
EBC ELECTRONICS
Level 2:
  • Expert 163 Answers
  • Posted on Sep 26, 2011
EBC ELECTRONICS
Expert
Level 2:
Answers
163
Questions
0
Helped
88806
Points
313
The unit is ok. User manual on page 42 says that the digital sources can not be output trough multisource output.
Try to use VCR-1 VCR-2 audio output jacks instead.
Is it possible to add a sumo amp to a Denon AVR
Yes, it is possible to add a Sumo amplifier to a Denon AVR (Audio/Video Receiver) system. The Denon AVR is designed to be the central hub for audio and video processing, providing amplification and routing signals to speakers and other audio devices.
To add a Sumo amplifier to your Denon AVR system, you can follow these general steps:
1. Determine the audio output options on your Denon AVR: Check if your Denon AVR has preamp outputs, which are typically labeled as "Pre Out" or "Main Out." These outputs are used to connect external amplifiers like the Sumo amp.
2. Identify the input options on the Sumo amplifier: Check the inputs available on the Sumo amplifier. It should have an input that matches the output from your Denon AVR. The most common connection is RCA, but there could be other options like XLR or optical.
3. Connect the Denon AVR to the Sumo amplifier: Use appropriate cables to connect the preamp outputs of your Denon AVR to the inputs of the Sumo amplifier. For RCA connections, you will need RCA cables with male connectors on both ends. Make sure to match the left and right channels correctly.
4. Configure the Denon AVR: Once the connections are made, you may need to configure the Denon AVR to use the external amplifier. Check your Denon AVR's manual or menu settings to disable the internal amplifier for the connected speakers. This will ensure that the AVR sends the audio signal to the Sumo amp instead.
5. Set up the Sumo amplifier: Follow the instructions provided with the Sumo amplifier to set it up correctly. This may involve adjusting gain levels, selecting input sources, and configuring any other settings specific to the Sumo amp.
6. Test and enjoy: Once everything is connected and configured, test the system by playing audio through your Denon AVR. The audio signal should be amplified by the Sumo amplifier and sent to your speakers, providing enhanced power and performance.
It's worth noting that the specific steps and options may vary depending on the models of your Denon AVR and Sumo amplifier. It's always recommended to consult the user manuals for both devices and, if needed, seek assistance from an audio professional or the manufacturers' support teams for detailed guidance tailored to your specific equipment.
This MIGHT help a little
Denon AVR-2802 Optical Issue
If you look at page 16 of the user manual it tells you how to assign the devices to the optical connections. Once this is done it should work.
If you don't have the manual just type "denon avr 2802 manual" into Google and it will show a free PDF file of it. On my search it came up first!
1helpful
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
I have an avr 3200 can it use 2 coaxial inputs and how good is the sound quality compared to newer avrs
Denon being one of the best names in the biz and this being an upper-crust modfel, I'd say anyone without a 'golden-ear' would be hard pressed to t\distinguish its sound from any other amplifier in existence.
The Denon site doesn't list and AVR-3200, but the AVR-3300 has 1 coaxial digital audio and 3 optical digital audio inputs.
If you're looking to run multiple coaxial devices and there aren't enough inputs this is what I do...
Helpful hint: Coaxial digital audio cables can be joined using an RCA cable splitter so they can share a given input or distribute a given output to multiple places. You just have to remember to have only the DESIRED units turned on when sharing or there will be digital confusion on the buss and it will result in silence or horrendous noise.
I have connected an audio source to the optical input channel 3 on my Denon AVR3300 but cannot get any audio thru mu speakers. The CD and Blueray connected to channels 1 and 2 work fine. What other...
If you have the User Guide for the Denon 3300, go to the "setting the digital inputs" section. The input settings are in the on screen menu called "system setup menu", then move down to "digital inputs".
Make sure that input you are having problems with is selected properly to "Optical".
The Denon 3300 guide is a mess I know and not user friendly in the least.
I have been using the 3300 for 9 plus years with no failures.
2answers
Denon receiver AVR-3300: Unstable source selection
Go over here: http://denon.custhelp.com/cgi-bin/denon.cfg/php/enduser/std_alp.php?p_sid=1NlVrsDj
I have some Denon components myself and had some problems. Ask them here, and within a day you should have solution for this problem.
Probably you have to reset the device to factory settings.
2answers
No system configration display on AVR3300 since moving.
Make sure the S-video and the composite cable are not plugged in it the same time from the Denon of at the Plasma
We have a Denon AVR Surround Sound receiver, a Samsung HDTV, an XBox 360, an ASD-3W Denon Ipod Dock and Klipswitch speakers with a subwoofer, center channel and too bookshelf speakers. We need help...
HDMI input connect as follows:
1. Connect an HDMI cable from the Cable box to the TV/CBL HDMI input on the Denon.
2. Connect an HDMI cable from the Xbox to the DVD/HDP input on the Denon.
3. Connect an HDMI cable from the HDMI out-put on the Denon to an input on the Samsung.
You don’t have to use the optical output from these to devices since the HDMI cable allows for the transfer of both audio and video, if you have them extra use them in addition to the HDMI cable and last,
4. On front of denon after you setup and assign your optical connections, if you use them, once you select TV/CBL or DVD/HDP as a source, press the input mode button to select auto
Denon AVR 2800 digital hookup to PS3
If your TV has an HDMI input, hook up the PS3 w/an HDMI cable to the TV. This will give you a high def picture (set up the PS3 to output the max resolution your TV displays). That will take care of the video side.
Next hook up an optical cable from the PS3 to the receiver. In the PS3 menu, you have to change the audio settings to output the sound via the optical cable.
Finally to get sound out of the receiver to the speakers, you have to setup the receiver source input. For example if you setup the PS3 to play thru "VCR" input, then you have to make sure the VCR input is setup to use either optical 1 or optical 2 for sound (whichever one you have the optical cable plugged in from the PS3).
  • I found this solution on a different site... it worked for me. I needed to change the sound settings in my ps3 to optical... then i selected dolby 5.1.... that took care of my sound.
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
