TV will turn on, but won't respnd to any button pushing or remote control. When tv is turned on there is no picture or sound, the screen says please wait and then goes dark. please advise.
Replaced main board and inverter board, still says "PLEASE WAIT" THEN GOES BLANK!Replaced main board and inverter board, still says "PLEASE WAIT" THEN GOES BLANK!
You can't post conmments that contain an email address.
Do you have a separate Cable Box? It sounds like you are shutting off the signal to the TV and may have to push a 'TV' button the remote then the 'off' button to actually shut down the TV.
These are the universal remote control codes to Vivo TV. 0004 0005 0009. Check this link to know more codes and proceedings to other brands of remote controls, and buy one remote control that has setup codes with your TV. The above said codes are for GE remote with Vivo TV.
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Hello First of all, you must ahve its original remote control to unlock FPA lock. If you have it, go through the folloing steps. * Hold down Menu button on the remote control, and the Volume Down button on the at the same time for at least 4 seconds. "The set won't say so, but the lock will be released". ** Hold down Zero button on the remote control, and the Volume Down button on the TV. The set won't say so, but the lock will be released. *** Hold down Menu button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. The set won't say so, but the lock will be released.
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work • If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then turn on again. If this happens frequently, the voltage in your house may be abnormally high or low. • Unplug TV. Wait five minutes. Plug it in again.
Can you turn the TV usin g the power switch on the TV? Testing remote control: The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals. Parts: www.shopjimmy.com www.remotes.com http://www.remotecontrolscenter.com http://www.newremotecontrol.com/ http://www.replacementremotes.com
On most TVs, all the picture and sound adjustments are made through on-screen menus. To get to them, you need the original TV remote control (or a compatible replacement) with the proper MENU functions. On some sets there's one main menu to work through, while others have separate buttons for picture and sound control settings.
Some brands and models of TV have a front-panel menu button. Maybe yours does. Sadly, though, many sets now have just a power button and need the remote control for everything else. The biggest trouble I find is that people get used to using the remote that comes with a cable box, satellite receiver or similar device which will turn the TV on and off but that's all. The original remote mysteriously gets lost (I've actually run into people who threw the original control out because they didn't think they needed it), and then you find you can't get at any other TV settings. It's especially annoying if you can't switch to another input, say for a game console or DVD player.
Hopefully, you still have your control. Good luck, and thanks for using Fixya!
Press Menu Button from any Remote control ( RC) by which could turn on your TV, press menu , menu drop down list will be visible on ur screen then wait 4 a minute or more till ur RC stop blinking , then go to Preference menu , go to FPA lock, turn it off. enjoy. Deva
