Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
SOURCE: Lightning strike nearby caused momentary power
Main AC fuse is encased in the black shrink tubing, labeled with Fx next to two pin white AC input terminal; http://assets.shopjimmy.com/media/catalog/product/cache/1/image/5e06319eda06f020e43594a9c230972d/s/j/sj1av4u20c17400.jpg
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=Sanyo+DP42848+&stock=all&limit=100
SOURCE: hit by lighting replaced power supply board same
When massive power surges to the tv.The tv Tuner signal board have 50/50 chances also dead too.In ur case it did.That the board,where the incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
SOURCE: Sanyo DP50747 Replaced Power Supply still not working
this issue is related to either the y sustainer and z sustainer boards, checking the fuses on the y/b will giving you a good indication, if they are open(bad) then you'll have a easy fix, if not, i would try replacing the y board first.
SOURCE: Hey,trying to determine which is
Main power supply unithttp://www.shopjimmy.com/samsung-lj44-00092f-power-supply.htm
Sub power board
http://www.shopjimmy.com/sanyo-b10n1660a-j3vk-power-supply.htm
feel free to email me @ [email protected] if you need more help
