Dear Sir:
Thank you by your question, here some answer:
PROBLEM: The power does not turn on
SOLUTION: a. Make sure that the power cord is plugged into a surge suppressor, and that the surge suppressor
is plugged into a properly grounded outlet . Use only a single-outlet surge suppressor
that meets all of the specifications . Important: The treadmill is not compatible
with GFCI-equipped outlets.
b. After the power cord has been plugged in, make sure that the key is inserted into the console.
c. Check the reset/off circuit breaker located on the
treadmill frame near the power cord. If the switch
protrudes as shown, the circuit breaker has
tripped. To reset the circuit breaker, wait for five minutes.and then press the switch back in.
d) Please check the power cord maybe is broker Testign with DVOM(Digital Voltimeter).
e) Test the circuit breaker of the House, and Reset, see in outlet box if some wiring is loose.
Thank you in advance, sincerely. Blessing.
If you need additional Help, please contact me.
E.CUADRA
Managua, Nicaragua.
