Air bag light flashes 5 times then 1 time
That flashing indicates fault code 51. Fault code 51 indicates a problem with the driver's seat belt circuit. The seat belt buckle has a switch in it to determine if the belt is buckled up when the seat is occupied [determined by a pressure sensor in the seat bottom]. The switch in the buckle is either bad or the wiring to the switch is either short or open circuited.
Use of a computer scan tool can help narrow down the problem. There are four different scan tool fault codes relating to code 51. They are B2432, B2433, B2434 & B2435. These codes will give you more defined information on the actual fault. Most common faults are either a bad switch in the seat belt buckle or damaged wiring to that switch. Damaged wiring is usually caused by the driver placing objects under the driver's seat, which damage the wiring coming out of the seat belt. It is also possible to have a bad seat belt computer [Restraints Control Module or RCM]. A bad RCM is not common. Check for damage to the seat belt wiring under the driver's seat. Best to remove the seat and lift up the carpeting to do this. If no physical damage or water corrosion damage is present, replace the seat belt. After repairs, disconnect the battery for 1 minute to clear the fault code from the RCM's memory.
