Computers & Internet Logo
Schinn Latush Posted on Sep 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Format aspire4736z - Computers & Internet
Anonymous
Level 3:
Guru:
  • Master 767 Answers
  • Posted on Sep 25, 2011
Anonymous
Master
Level 3:
Guru:
Answers
767
Questions
0
Helped
188191
Points
1958
Hi there.
To format you will need:
Operating Systems (OS) CD/DVD
Steps:
1) Enter the BIOS when the laptop boots by pressing the Delete key repeatedly.
2) Once the BIOS is open locate the boot disk priority and set prioity 1 to the CD/DVD drive, set priority 2 to the laptop's hard drive.
3) Save changes to the BIOS and exit. The system should now reboot.
4) Insert your OS CD/DVD.
5) Press Enter when the system asks you if you want to boot from the CD/DVD.
6) The OS setup should now start, the first thing it will ask you to do is format your hard drive.
7) After you drive is formatted you can either continue with the setup and install a fresh copy of the OS or you can exit leaving the main drive clean.
~ Slasher_X
Aluminum foil is congealed on my stove top. Is it worth it or even possible to replace the top.If so where can the model number be found.
Computer Ko Format Kaise Kare? - ????? Laptop Format Karne Ka Tarika ????? ???!
???? ??????? Hindi Sahayta??? ???? ?????? ?? ?? ?? ????Computer Ko Format Kaise Kare?? ???? ??? ??????? ?? ??? ?? ?? Windows 10 Ko Format Kaise Kare ?? ???? ??? ??????? ??? ?????? ?? ?? ???? ????? ????? ???? ??????
???? ?? ??? ??? ????? ????? PC Format Kaise Kare ?? ???? ??? ?? ??????? ?? ???? ??????? ???????? ?? Knownledge ?? ????? ?? ?? ??? ?? ????Computer Format Karne Ka Tarika????? ????? ?? ?? ?? ???? ?? ????? ??? ??? ???? ??? ??????? ?? ???? ??? ????? ????? ?? ????? ?? ????
???????? ??? Virus ???? ?? ???? ???? ?? Problem ??? ???? ?? ???? System Hang ???? ???? ??, ???????? ???? ?? Restart ???? ???? ??, ???????? ?? Speed ?? ?? ????, ????? ???? Pc ?? Data Delete ?? ???? Etc. Problem ?? ???? ?? ?? Problem ?? Solution ?? ??? ??? System ?? Format ???? ????? ?? ???? ???
Contents [ show ]
?? ???? ?? ???? ? ???? ???? ?? ???? ?????? ?? Format ???? ???? ?? ???? ?? ???? Windows Update ?? ??? ?? ?? ???? ??? Drive ?? Format ???? ????? ?? ?? ?? ??? ???? ?? ???? ???
?? ???? ?? ?????? ??? ???? ? ???? ??? ????? ?? ?? Pc Format Kaise Karte Hai ?? ???? ??? ????? ????? ?? ???? ?? ??? ?? ????? ????
?? ??? ??? ???????? ?? ???? ??? ?? ????? ?? ????? ???????? ?? Format ???? ?????? ????? ???? ??? ?? ?? Computer ?? C Drive ?? Directly Format ??? ?? ???? ???? ??? ???? ??? Boot Menue ?? Format ???? ???? ??'
???? ??? ???? ?? Boot Disc ????? ???????? ?? Format ???? ?? ??? ???? ??? Windows Operating System ?? CD (Bootable DVD) ???? ????? ???? ???? ?? ???? ?????? ?? Format ??? ?? ????'
???? ???: Facebook Par Kisi Ko Block Or Unblock Kaise Kare - Facebook ?? ????? ?? ??????? ???? ?? 4 ???? ?????!
???? ??? ???? Windows Operating System ?? File ?? ?????? ???? ??? ???? ??? Windows Operating System ?? File ?? ?? ?? ???? ???? ?? Help ?? ???? System ?? Format ?? ???? ??? ?? ?? ??? ??? Bootable CD/File ??? ?? ?? ?? ??? ??????? ?? Download ?? ???? ???
???? Laptop ?? ???????? ?? Format ???? ?? ???? ???? ???????? ??? Save ??? ?????? Data ?? ???? Pendrive ?? ???? ???? Device ??? ??? ?? ?????? '
??? ?? ?? ???? Data ?? ??? ?? ??? ??? ???? ?? ?? ???? Data Delete ?? ???? ?? ?? ???? ????? ?? ?? Pc Format Kaise Karte Hai ?? ???? ??? ???? ?? ??? Steps ?? Follow ????
Step 1: Boot Key ????? ???
???? ???? ???? ???????? ?? Restart ???? Open ??? ?? Boot Key (F12) ?? Continuously ????? ???? ????
Step 2: Bootable Disc Insert ?? ??
?? ???? ????? ???????? ?? Screen ?? ?? Message Show ???? ?? ???? ???? Boot Device CD/DVD Rom Select ???? ???? CD Rom ?? Select ???? ?? ?? Window 7, 8 ?? Bootable Disc CD Drive ??? Insert ?? ???
Step 3: Press Any Key
???? ?? ?? Cd Rom Select ?????? ?? ???? ???????? ??? ?? Restart ???? ?? ?????? ?? ???? Screen Black ?? ????? ???? ?? ???? Press Any Key To Boot From Cd/Dvd ?? ???? ????? ?? ??? ?? Key ?? Press ???? ???
Step 4: Windows ??????? ???
?? ???? Window10 ( ?? ??? Windows ?? ???? ???????? ?? Format ???? ????? ?? ??? Select ??? ???? ???? ?? Windows 10 Bootable Disc Select ?? ?? ) Disc ??? 2 Minute ?? Read ????'
???? End ???? ?? ??? Installation Window Open ???? ?? ?? Installation Window Button ?? ????? ???? Installation Process ?? ???? ?? ???? ???
Step 5: Install Now ?? ????? ???
Install Now Button ?? Click ???? ?? ???? Windows10 Setup File ?? Copy ????? ???? Window ?? 2 Minute ?? ???? ?????'
???? ???: ATM Kya Hai? ATM Kaise Use Kare? ATM ?? ???? ???? ??????? - ATM ?? ???? ???? ???????!
?? Windows Setup Files ?? ???? ??? ?? Copy ?? ???? ?? ???? ?? ?? Window Open ???? ???? ???? Update Install ???? ?? ??? ?????? ????? ?? Online Update ?? Select ???? Manually Update Select ????
Step 6: Windows Bit Select ???
???? ?? ?? Manually Update ?? Select ?????? ?? ?? ?? Installation Window Open ???? ???? ?? ???? X80 ?? X60 Type ?? Windows BIT Select ???? ?? ?? ?? ?? BIT Select ???? ???? ?? ?? ???? ?? ?? Next Button ?? Click ????
Step 7: Drive ??????? ???
?? ?? ?? Installation Window Open ???? ???? ???? ???? Drives Open ?? ????? ????? ???? C Drive ?? ??? ??? ?? Windows ?? Format ???? ????? ?? ?? Drive Option ??? Click ?????? ?? C Drive ?? Format ?? ???
Drive ????? ??? ???? Drive Manage ???? ?? Option ?? ?????? ????? ?? Drive C,D,E ?? Format ?? New Partition Disc ?? ??? ???? ???
Step 8: Next Button ?? ????? ???
C Drive ?? Format ???? ?? ??? ???? Windows10 ?? Install ???? ?? ?? ?? ??? ?? C Drive ?? Select ???? Next Window ?? ????? ?? ?? ???? ?? ?? Next Button ?? ????? ???? ?? ?? Windows10 Installation Process Start ?? ???? ???
?? Windows10 ?? Installation Process ???? ?? ???? ?? ???? ???? ???????? 1 ?? 4 ??? Auto Restart ???? ?? ??? ???? ???????? ??? ??? ???? ????? ?? ?? ?? Windows10 Bootable Disc ?? Eject ????
?? ??????? ?? Laptop Format Kaise Kare ??? ?? ??? ????? ???? ???? ??? ???? ??? ???? ???? ??? ????? ?? ????? ?? ????? ?? ???? ????????, Laptop ?? Format ?? ???? ???
7helpful
How to format a N77 beacuse i forgot my security code
There are two types of formats one is the soft format and the other is the hard format. The soft format restores your phone to factory settings, all data is not erased in this type of format. The hard format erases the whole data. There are two codes to perform the two formats respectively: for soft format *#7780# and for hard format *#7370# after typing both the codes you need to give the security code but you dont remember, so there's one more way to format your phone: switch off your phone. Hold*,3,green(calling)key and switch ON/OFF button together. The formatting progress will be displayed. Remove your hand from the keys after the format is completed... Rate my answer..
28helpful
5answers
Memory card not formated operation failed
Sometimes, Due to viruses or hidden data in the memory card, the handset is unable to format the memory card. so if u format it from a pc, using a card reader, your mem card will surely get formatted easily.. But if there is some technical problem in formating, download HP DRIVE KEY BOOT UTILITY It repairs up and formats the corrupted data and your memory card will be ready to use again .. Happy formatting !
Sir/mam..i bought an acer aspire4736z windows7 ready. im having problems with my microsoft programs,and my computer is installing some updates that always fail and i tried to uninstall some of those failed...
It is very common that Windows Updates don't actually update. I just leave them and my file is extensive!
Just let Windows prat about and do what it thinks your Notebook needs. It won't do any harm.
1helpful
2answers
Plz Help me ....How to Format Computer.......
How to Format a Computer
Want to know how to format a computer hard drive? Need to learn how to format your computer and start with a clean slate? Formatting a disk prepares the surface of the drive to accept and store data. Computers are often formatted before they are sold, donated, or returned to an employer. Likewise, computers with viruses or errors can be formatted and returned to their "out of the box" settings.
How to Format Computer Quick Links:
Cannot format octagon veridisk T118 usb
Try this
Microsoft Windows 95, 98, ME syntax
Formats a disk for use with MS-DOS.
FORMAT drive: [/V[:label]] [/Q] [/F:size] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/T:tracks /N:sectors] [/B | /S] [/C]
FORMAT drive: [/V[:label]] [/Q] [/1] [/4] [/B | /S] [/C]
FORMAT drive: [/Q] [/1] [/4] [/8] [/B | /S] [/C]
/V[:label] Specifies the volume label. /Q Performs a quick format. /F:size Specifies the size of the floppy disk to format (such as 160, 180, 320, 360, 720, 1.2, 1.44, 2.88). /B Allocates space on the formatted disk for system files. /S Copies system files to the formatted disk. /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. /C Tests clusters that are currently marked "bad." Microsoft Windows 2000 and Windows XP syntax
Formats a disk for use with Windows 2000.
FORMAT volume [/FS:file-system] [/V:label] [/Q] [/A:size] [/C] [/X]
FORMAT volume [/V:label] [/Q] [/F:size]
FORMAT volume [/V:label] [/Q] [/T:tracks /N:sectors]
FORMAT volume [/V:label] [/Q] [/1] [/4]
FORMAT volume [/Q] [/1] [/4] [/8]
volume Specifies the drive letter (followed by a colon), mount point, or volume name. /FS:filesystem Specifies the type of the file system (FAT, FAT32, or NTFS). /V:label Specifies the volume label. /Q Performs a quick format. /C Files created on the new volume will be compressed by default. /X Forces the volume to dismount first if necessary. All opened handles to the volume would no longer be valid. /A:size Overrides the default allocation unit size. Default settings are strongly recommended for general use.
NTFS supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K.
FAT supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes).
FAT32 supports 512, 1024, 2048, 4096, 8192, 16K, 32K, 64K, (128K, 256K for sector size > 512 bytes). Note that the FAT and FAT32 files systems impose the below restrictions on the number of clusters on a volume:
FAT: Number of clusters <= 65526 FAT32: 65526 < Number of clusters < 268435446
Format will immediately stop processing if it decides that the above requirements cannot be met using the specified cluster size.
NTFS compression is not supported for allocation unit sizes above 4096.
/F:size Specifies the size of the floppy disk to format (160,
180, 320, 360, 640, 720, 1.2, 1.23, 1.44, 2.88, or 20.8). /T:tracks Specifies the number of tracks per disk side. /N:sectors Specifies the number of sectors per track. /1 Formats a single side of a floppy disk. /4 Formats a 5.25-inch 360K floppy disk in a high-density drive. /8 Formats eight sectors per track. Microsoft Windows 2000 and Windows XP recovery console syntax
format [drive:] [/q] [/fs:file-system]
drive: Specifies the drive to format. /q Performs a quick format. /fs:file-system Specifies the file system to use (FAT, FAT32, or NTFS) Examples
When using the format command, remember all information on the drive you wish to format will be completely erased.
format a:
Would erase all the contents off a disk. Commonly used on a diskette that has not been formatted or on a diskette you wish to erase.
format a: /q
Quickly erases all the contents of a floppy diskette. Commonly used to quickly erase all information on the diskette.
format c:
This would erase all the contents of your C: hard disk drive. In other words, unless you wish to erase all your computer's information, this command should not be done unless you're planning to start over.
Or
Right click My Computer-->Manage-->then go to Disk Management
and select the to format right-click it and click format. Thats it Your drive will format and You can also choose in which file system you want to format your drive.
For further help or to thank me mail me on my email [email protected]
5helpful
Unable to send data and format too
Try this,
Download and install the low level format tool using the link provided below,
http://hddguru.com/download/software/HDDGURU-Low-Level-Format-Tool/LLFsetup.2.36.1181.exe
Format your Flash Drive using this tool. After this format, please make sure to format it once normally by right clicking on removable disc in My Computer and click format. Second format is neccessary since low level format will remove the File System data even and second format will again create that file system.
Also,please make sure that you select FAT32 as the file system while formatting it for the second time.
Grand Canyon Tech
Grand Canyon Tech
