Question about Asko W6441 Front Load Washer
ZJ - thanks for responding to my f2 problem. I'm actually referring to my asko w6441 washer. I think your reply was in reference to a dryer. Do you have information on an asko washer f2 error code? The manual says to call a technician. I'm wondering if I can fix it before calling a technician. Thanks!
    Top Expert:
  • Asko Master
  • 10,627 Answers
Possible communication to motor possible bad
Posted on Sep 29, 2018
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 59 Answers
SOURCE: Asko washing machine has no power
check your ground fault interupters (outlets with butons) under the sink and around the kichen
then check the breakers in your breaker box
finaly call a sertified tecnition
Posted on Jan 22, 2009
praky16
Prakash Ram
  • 744 Answers
SOURCE: ERROR F3 - WHAT DO I DO?
hi the error shows bcoz of ur door problem...
replace the door lock and ur problem will be solved...
Posted on May 24, 2009
canbruce75
Bruce Canfield
  • 1776 Answers
SOURCE: My Asko W6441 front load washer F3 message
Hello. You said that you checked the drain line for obstructions, but did you check the pump? I would remove the hoses from the pump and using a flashlight, look into the suction port on the pump. Check the pump for any obstructions (like the occasional stray sock) and check the pump impellers. Look for broken/missing blades and ensure that the impeller spins freely. If there are missing/broken blades or if you cannot get the impeller to spin freely, the pump is defective. You may have already done this, and if so I apologize. Anyway, hope this helped and best wishes.
Posted on Aug 28, 2009
Macmarkus
Mark MacDonald
  • 2605 Answers
SOURCE: asko w6441 housekeeper pushed buttons too
Hello John, Welcome to FixYa. I can provide you with an Asko service manual that should guide you on how to remove the panel and anything else you may like to do as well. The service guide I have is an Asko W600 series ( that includes yours ) from Asko in "pdf" so I could attach it to the email address you provide if you give the go ahead. I'll watch for your reply. Regards, Macmarkus :)
Posted on Jan 15, 2011
W6441 Error message
google this with the model # and the brand along with the F4 error code
Jul 25, 2015 | Asko W6441 Front Load Washer
Asko service
Please refer page 12 and 24 in the washer manual to find out how to open the locked door. You have to press the door open button for 3 secs at end of cycle.
Asko Front Load Washer Use and Care Guide W6021 W6441 W6761...
Aug 10, 2014 | Asko W6441 Front Load Washer
Can't download manual for W6441 washer
Here is the link for your manual you requested.
Manual
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 28, 2011 | Asko W6441 Front Load Washer
Stopped mid cylce and now has no power
The problem sound`s like it could be a fuse, but first you`d need to verify the model number. ( past experience dictates I can`t count on the one at the post heading, sorry. )
If it is indeed an Asko the fuses will be located at the back above where the power cord exit`s the washer. Unplug the washer either from the wall or the dryer ( or unplug the dryer if connected to the dryer, either way ) With a flat screwdriver fitted in the slot of the fuse hub, turn it a quarter turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part. Replace with a 15amp "slow blow" fuse if blown ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color )
I`ll assist you further if need be once I see a model number. Hope this was helpful, if so please take a moment to rate it. Thank you and good luck.
macmarkus :)
Mar 30, 2010 | Asko W6441 Front Load Washer
Aug 28, 2009 | Asko W6441 Front Load Washer
May 24, 2009 | Asko W6441 Front Load Washer
Jan 22, 2009 | Asko W6441 Front Load Washer
Using asko washer front load
Close the door firmly.  It won't start until the door is sealed shut.
Dec 10, 2007 | Asko W6441 Front Load Washer
Asko W6441 Front Load Washer Logo
144 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
ROB
Lollo Pop
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
