Heating & Cooling Logo
Posted on Sep 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an Emerson (4 Speed) direct drive blower for my gas furnace. What is the process (wire color codes) to change speeds on the blower. (I have a red, black and yellow wires taped off in the wire loom) I want to cut the speed down from Med/High to Low/High. Thank you very much
Anonymous
Level 2:
New Friend:
Teacher:
An expert who has written 2 tips or uploaded 1 video tip.
  • Expert 59 Answers
  • Posted on Sep 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Teacher:
Answers
59
Questions
0
Helped
39726
Points
144
There should be a wiring diagram on the motor itself. The colors of the wires vary depending on voltage and model. Generally you have a med/low and med/high setting, I'm not sure what you are getting to with the low/high setting unless you are trying to set up staging. Check the motor for a diagram, if that is not present post back with all of the wire colors coming from the motor and the voltage.
01 Sequoia wiring color code diagram
  • Black: Ground
  • Blue/White: Power (12V) from HVAC control unit to blower relay
  • Blue/Yellow: Power (12V) from blower relay to blower motor
  • Blue/Black: Ground from blower motor to chassis
tip
Furnace Troubleshooting
On some natural or LP gas furnaces, the blower motor has to come on 1st
and then shuts off. This process starts the inital call for heat. If you find
yourself without heat and the blower does not run, turn the furnace to on
at the thermostat.
When changing the fan to on, you are changing the speed, if the heat comes on, that means you have a burnt out speed on your blower motor.
If nothing happens, change the fan speed at the control board.
In some instances they may be using the same blower speed in both the
heat and cool mode.
on Jan 19, 2010 • Heating & Cooling
Rudd Rheem 1068-311 62-23599-04 board how do I change blower speeds?
psc motors have 4 speeds each colored black blue yellow red and white. there are speed taps on the board labeled heat, cool, even heat/cool and usually Park or M1 male spade fittings for the unused speeds. on the door will tell you speed chart by wire color ie black is high and red is low speed. newer models ask you not to use red for heat. to change speeds is by changing wires and their system mode taps. (beware the push release female end locks into the board) If using black for both and there is a heat/cool tap make sure that the separate taps cool or heat are empty, or motor will receive 120 volts twice. 1 thing to remember a 3.5 ton blower with a 2 ton air cond. wouldn't want to use black too much air flow.
If you have a variable speed its all in the bible for a manual and which dip switch position for cfm air flow.
Need to wire furnace blower
Gas valve should only have a couple of wires...24 Volt & common. the blower will use one speed on a gas furnace & a common. If you have AC or a fan switch on your thermostat, then the high speed will also be connected on the blower.
Can't get the gas furnace to heat.
All York/JCI thermostats made by Venstar
The setup is probably incomplete. Did you configure the thermostat for a 2 stage heat pump? The heat pump should have a thermostat wire connected to R, C, Y1, Y2, and O, that makes 5 wires. I suspect you are only using first stage compression and or first stage blower speed.
1helpful
Is there a hi/low setting for the fan on my Bryant gas furnace? i can't seem to get enough warm air up on the top floor. .
Your homes ductwork needs to be balanced. Get someone that can read airflow...personally I use a balometer made by alnor. Ir is probably not a fan speed issue, but if you want to check the speeds of the fan, it should be a 3 or 4 speed motor. Look @ what color motor lead is attached to heat terminal on the circuit board, and if necessary, change to the higher speed motor lead that is not use (on an unused terminal)
I have a Lennox Diplomat furnace. How can I tell if the blower motor is set for high speed when it comes on?
The only way to really tell if the blower is set to high is to look at the control board inside the furnace and see how it is hooked up. You will have either a 3 speed or 4 speed blower motor, more than likely a 4. These are Hi, Med Hi, Med Low, Low. Each speed has its own color and if the motor has ever been changed, it could be different from factory diagrams. The most common colors/speeds are:
Black- Hi
Blue- Med Hi
Orange- Med Low
Red- Low
You could have different colors but they will be close. If it's an aftermarket motor, the speeds will be listed on the motor itself, but very difficult to get to sometimes. On the board, you should have terminals marked, COOL, HEAT, PARK, PARK. You hook what speed you want for Cool and Heat and put the other 1 or 2 wires on Park.
Again, these might not be exact, but these are the basics and they usually don't deviate from them to much unless it's a 95% furnace or such. If you do have the diagram for the furnace, you will be able to find everything with no problem now that you have the basics. Also keep in mind that you will have a Common wire from the motor that hooks to Com. terminals on the board. Hope this helps and good look!
1helpful
Can I change airflow direction with Goodman GMS8?
I would probably use a furnace for the correct application. However some motors do have a reverse speed connection. Besides the blower speed taps,
capacitor wires and the nuetral wire. There are two wire sets that you can switch that can do this if your blower motor is equipped.
You might experience some airflow problems, probably a lack of airflow, if the furnace was installed
as an upflow model instead of a counterflow.
Reduce blower speed
Motor speeds on the blower are always remember black is high, blue in med. and red is low sometimes blowers are 4 speeds but the main colors are the black blue and red. Now where to change locate the wires coming from blower to a box or control board. control board has setting for heating and cooling speeds for the blower. You might see blue on heating which would be medium speed so take the red off park terminal and change places with the blue. Now if you have a fan control switch it looks like a dail in the middle of the furnace with numbers on the face with pointers set at the numbers. follow the wires from there to the electrical box and open box. find color of blower and switch be sure to cap off the wire you change. Wire nut would be good.
Top Emerson Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
