Input/Output Cord I am in need of a input/output cord to a 32" Protron LCD television which has been misplaced during my recent move. My husband recalls the devise having two ends. Protron PLTV 32" LCD TV Model Name: LU32A1A3 Input: 100-240V 50-60Hz 3.0A MAX Output: +24V - 6A +12V - 3A At your earliest convenience, please respond to this e-mail.
Many new TV's do not have a standard coaxial input anymore. The industry has moved on from that and you might have to get an external tuner to get an input like that. I found an old review from 2006 and it shows the antenna input on the bottom side where the power cord plugs in. http://www.geek.com/xyzcomputing/norcent-lt-2722-27-inch-lcd-tv-571351/
Tries websites like Amazon.com,Ebay.com to buy A/C power cord for ur LCD tv.Power A/C cord are generic products,not in any particular LCD tvs models.Just look in the A/C power cord input hole in ur tv,and the picture of the Power A/C cord u going to buy.Compare they matches u buy it.Will not find any specsific power A/C cord to any LCD,PLasma tvs or DVD players.Because A/C power cords are generic products,fit with many brands.
The response to your question is in two parts. There should be a couple of RCA jacks on the rear or side of the set labeled "output". These need to be connected to the input of the wireless headset transmitter. The second thig is to determine where the volume is to be controlled. The output from the set can be either Fixed or Variable. This means that teh volume can be controlled by the volume up/down at the set or not. Fixed mode is for connecting to a receiver where the volume is controlled by the receiver and changing the volume at the set will have no effect. Using the variable output mode will allow you to control the level of audio entering the transmitter and thus the volume. This assumes that the headphones do not have a volume control on them.
Setting the output to be either Fixed or Variable is controlled by the audio menu of the set. Please note that in variable mode, any internal speakers would need to be disabled as well.
Try website. -
http://www.lcdpayless.com I placed my
order on Thursday and went out of town for the 4th and I checked my
mail today (Monday) and it was there. I plugged it in, the power came
on and the tv works perfectly....plus the new cord doesn't have an
annoying fan.
The cord is pricey at $117, but it beats buying a new tv. The company
accepts returns minus a 20% restocking fee and shipping, so I figured
worse case scenario I would only be out of $40+bucks if it didn't work
and I had to send it back. Hope this
helps!!!
an output like ( HDMI ) would be on a dish reciever , and a hdmi input on a tv would plug into that output on the dish reciever
Is HDMI what you are trying to connect? then you would need an HDMI cable
HDTV = High Definition television , which means that you have a built in digital tuner that will pick up the digital and high definition broadcast channels with an antenna connected to the tv
THE BEST INPUT ON YOUR SET IS THE HDMI INPUT.2ND THE COMPOSITE INPUT. 3RD THE COMPONENT INPUT. AND 4TH THE ANTENNA INPUT. MOST DISH BOXES HAVE AT LEAST THE COMPONENT OUTPUT. YELLOW IS THE VIDEO AND RED AND WHITE FOR AUDIO. USE RCA CABLES TO GO FROM BOX TO LCD SET. ON THE DISH BOX YOU CAN GO FROM ANTENNA OUT TO THE CABLE OR ANTENNA IN ON THE LCD. SWITCH TV TO CHANNEL 3. AND TURN YOUR DISH BOX ON.
I found a replacement adapter at LCDPAYLESS.COM it will arrive soon I will log-on as soon as I get it to let you know if it works. I never ordered anything from them before hope it works. Also i will keep my receipt and seen it to protron to have them refund my money
