Ricoh Aficio 450 Copier Logo
Anonymous Posted on Sep 26, 2011
Ricoh afficio 1015 code error, appearing sc302 on screen
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Oct 03, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
3455
Points
7
Check and replace charge roller
gggg
Level 3:
  • Master 904 Answers
  • Posted on Oct 13, 2011
gggg
Master
Level 3:
Answers
904
Questions
Helped
520465
Points
1791
Sc302 on the Ricoh Aficio 1015 is a charge roller current leak error. The most likely problem is the charge roller, which sits in the drum unit and provides a charge to the photoconductor. If you replace the charge roller (part #AD027018) that is probably going to take care of the problem.
If that doesn't fix it, the issue could be a bad high voltage supply board, which will be much more expensive to replace, so I'd recommend trying the charge roller first.
Rudy Serna
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on Feb 20, 2012
Rudy Serna
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
6337
Points
23
Dirty charge roller just clean it found in the PCU (photoconductor unit) but, problem occur again replace it. some of our unit will be solve by just cleaning the charge roller and the whole PCU assembly
  • Rudy Serna
    Rudy Serna Jul 03, 2014
    If you have replaced new charge roller and High Voltage Board and problem appear sometimes you need to repace OPC Drum.
Anant
Level 1:
New Friend:
Problem Solver:
  • Contributor 9 Answers
  • Posted on Apr 12, 2014
Anant
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
9
Questions
Helped
6830
Points
9
Change the OPC drum with cleaning blade. It will resolve your problem.
Nikolay Boychev
Level 3:
  • Ricoh Master 525 Answers
  • Posted on Jul 05, 2012
Nikolay Boychev
Ricoh Master
Level 3:
Answers
525
Questions
Helped
315004
Points
1297
SC-302 Charge roller current leak
Symptom: A current leak signal for the charge
roller is detected.
Possible Cause:
• Charge roller damaged
• High voltage supply board defective
• Poor connection of the PCU
1helpful
Ricoh aficio MP2000 ERROR code SC302.
https://printcopy.info/?l=en&mod=erc&brand=Ricoh&model=Aficio%20200&code=SC302
Ricoh Aficio 200 Error Codes
Ricoh Aficio 200 Error Codes Code:
Code
SC302
Description
A charge roller current leak signal is detected.
Causes
• Charge roller damaged • Charge high voltage supply board defective • Poor connection of the PCU
Functional problem sc302 in ricoh afficio 1315
this is a charge issue - a simple fix would be to remove the pcu and clean round its outside and then clean the contacts to it inside the machine - if this doesnt work the pcu needs stripping down
Funtional problem SC302
It depends on which Ricoh model.
Some Ricoh copier/printer use a corona wire for charging the drum, so SC302 means that the corona wire is ether broken or have some current leak. but in most case the wire is broken.
Other Ricoh copier/printer use a charge roller for drum charge, so on this model SC302 usually appear when the charge roller have a bad contact.
20helpful
3answers
How can i solve error code sc:302 in ricoh Aficio 2000 copier.
Is there any immediate solution for the ERROR SC302 for aficio 1018?
tnx
1helpful
2answers
Have an aficio 1018 copier with an error code SC544 any ideas ?
that's a fuser unit error do an Sc reset and restart the machine if not replace the fuser unit
2answers
Error code SC302
From the Ricoh-Lanier Error Code Sheet:
SC302: Charge Corona Output Error 3 - Grid Voltage error - Charger Roller Current Leak.
I would suggest replacing first the charge roller and if that doesnt fix it, the HIgh Voltage Supply Board.
2answers
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
2helpful
3answers
What error code 302 ricoh aficion 2016
Hi Manas,
Error code - SC302 is caused due to the leakage in charge roller.
In order to rectify the issue you need to replace the drum and the charge roller .
Nitin
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
