Garden Logo
Posted on Sep 18, 2008
Mower starts won't keep running
First off it would go chogchog, but kept running now it starts but after a few minutes it dies very hot. I've cleaned off the the air filter (very dirty) but it did it again any ideas?
  • tmcgrann72 Sep 27, 2008
    my mower was running fine, but then it just died and would not restart. I cleaned the filter, changed the gas, and drained the little bowl on the bottom. I found that there was water in the bowl so I took the gas tank off cleaned it dried it and let it sit for a day. I then put it all back together but it wont stay running, and sometimes I have to use starter fluid
  • Anonymous Mar 25, 2014
    runs for about 10 minutes and starts to spit and sputter and eventually dies
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 19, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
940
Points
Check the bowl under the primer button see if there is dirt in there watch how it comes apart,then send me email cant get mine back together,mine was dirty should help.
I've just got a Yamaha dt 125 R, I think it's a
You have to clean out the carburetor, lots of build up inside of it.
Jul 11, 2017 • Motorcycles
CX7300 Digital camera won't turn on. New batteries get hot after being put in the camera after a few minutes.
No. This camera requires service/repairs, the repairs will be more than this model camera is worth !!!!
Why won't my mower just run already?
Hi, most likely the carby has dirt in it again(if this is what the shop have been cleaning each time). If it comes good when cold the valves need adjusting. Regards Phil.
4helpful
Four stoke mower. Mower starts and runs ok but after a short time (10-15 minutes) the engine stops as though it has run out of fuel. Fuel tap on, filter clean, new spark plug. After a few minutes you can...
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
I have a 2004 Troy Built Poney 17.5 Briggs & Stratton Riding Mower runs for about 3 minutes with blades engaged then is starts to die on me. Sometimes if I dis-engage the deck blades it will keep...
what color is the spark at your sparkplug? If it's red, it's weak,if it's blue it's hot, clean the magneto contacts with sandpaper and wd40 and clean the coil too, let me know how you did!
Jun 05, 2010 • Mtd Garden
Engine starts right up after pushing primer bulb,
There is dirt in the nozzel inside the carb,take it apart and clean it with torch tip cleaners. Remember to replace all the gaskets you disturb.
4helpful
Lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Sep 19, 2009 • Garden
1helpful
Can't keep mower running without consistently pushing the primer.
It sounds like there is water in the gas. The only way to remedy this is to take the carb off of the gas tank and replace the diaphragm, there is a small reservoir between the tank and carb...clean with WD-40 to remove water
1helpful
Champion Vantage 35 - mower will not keep running
More than likely the jet in the carb is somewhat clogged. Did this just happen after sitting for the winter? If so, start the mower and when it starts to die pump the primer to keep it running. Sometimes it will clean itself in a few minutes. If not, carb cleaner or take the carb bowl off and clean the jet.
Hope this helps
Kurt
Pls rate the answer
Top Garden Experts
Jay Finke
Jay Finke
john h
