If the console lights up the problem isn't in your battery, most likely your lift motor and if you go through your manual which i will be attaching a link to, you will be able to find everything you need to know on how to calibrate your lift motor.
Link to your manual;
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/Service%20Manual,%20C546i%20Self%20Powered%20EFX.pdf
if you find you need any further assistance please do not hesitate to contact our Technical Support Team by phone 888-713-2880 or by visiting us online
http://www.sportsmith.net/productsearch.aspx?dsNav=N:11568
Always hear to help!
It doesn't always say low battery - check the battery first. If the battery is fine, then check the lower board and the incline motor.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
SOURCE: The ramp will not go up or down. It's states low
The ramp system has a battery monitoring system. If the battery voltage falls below 11 Vdc when the ramp movement is initiated or the battery voltage falls below 10 Vdc after ramp movement has been initiated, ramp movement will be stopped and gives that error message. The ramp will not be enabled until such time as the battery voltage exceeds the above limits. The battery voltage must be raised to be to correct this problem either by charging or replacing the battery.
