It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues. For replacement of bearings check for tips on this visual link: Thank You for using fixya
Before raising the rear of your Honda, remove the dust cup from the center of the brake drums using a hammer and chisel. This will give you access to the spindle nut, which you can loosen using an axle nut socket. Then you can raise and remove the wheel/tire assembly ,or assemblies if you are replacing the bearings on both wheels.
If your Honda model is equipped with rear disc brakes, remove the brake disc retaining screws, the brake hose bracket from the steering knuckle and caliper bracket mounting bolts. Hang the caliper to the coil spring using wire. Do not let the caliper hang free or the brake hose may be damaged.
At this point, you will be able to remove the brake disc by hand. However, rust may have a firm grip on the disc. If this is the case, use a couple of 8-by-1.25 mm bolts and screw them evenly into the brake disc threaded holes. This will push the disc off the hub. Now you can finish removing the spindle nut and hub/wheel bearing assembly and install the new hub/wheel bearing assembly using a new spindle nut
If your Honda Civic comes equipped with rear brake drums, remove the center grease cup and loosen the axle spindle nut using an axle nut socket. After raising and removing the wheel/tire assembly, finish removing the axle nut and washer.
You might be able to remove the outer wheel bearing from the spindle using a screwdriver. If not, wiggle the brake drum as you pull on it to let the bearing fall off the spindle. However, the brake drum might be caught in place by the brake shoes. In this case, you can retract the brake shoes through the hole in the back of the backing plate.
Remove the rubber plug from the back of the backing plate. Then rotate the star wheel on the adjusting screw using a brake adjusting tool as you push the lever off the start wheel with a screwdriver. With the brake shoes off the brake drum, pull the brake drum off the wheel assembly. Then clean the brake assembly with brake parts cleaner and a clean, lint-free towel.
Now you can set the brake drum on a workbench or hard surface and remove the grease seal and inner wheel bearing. The inner and outer wheel-bearing races can be removed using a drift punch and hammer. Pack the new wheel bearings with high-temperature wheel-bearing grease using a wheel-bearing packer and use a new grease seal during installation. Also, before reinstalling the brake drum, apply a thick coat of wheel-bearing grease to the cavity inside the hub, but do not fill it completely.
