According to Toshiba, the CT-90121 isn't a universal remote control. This remote only works with TOSHIBA TVs with the following model numbers:
32AFX62, 32AFX63, 32HFX72, 34HDX82, 36AFX62, 36AFX63, 36FX72, 36HFX72, 42HDX52, 42HDX82, 50HX70, 57HDX82, 57HL83, 57HLX82, 65HDX82, 65HLX83 Unless you posted the wrong remote model number (?) your Toshiba remote isn't going to work with your RCA TV.
Please rate this solution if you find it helpful. Thanks!
Hi Thanks
for using FixYa. You can buy the parts for your Toshiba 50HX70 from this link. Please
do rate the solution if the issue is resolved or post a comment for further
assistance. Thanks Rylee
When the convergence amplifier ICs go bad (STK392-xxx), they RARELY cause more than one color to go out. The fact that the top and bottom of the picture are effected indicates the vertical convergence IC. Replace both, and while you're in there check the bias resistors... it is likely one of these is open. Once the ICs have been replaced (as well as any open resistors), customer convergence followed up with the auto convergence should do the trick.
press mute button once after press and keep pressing mute again and press de menu button on tv .when tou see S on screen press 7 you are in convergence adjusting mode
Hi, you`ll need to call the tv guy then, you have a short in one of the power supplies, or possibly broken solder connections, either way the board has to come out and board repaired or parts changed, BMW Rider
