Question about HP PSC 1610 All-In-One InkJet Printer
It keeps saying check color cartridge. If the color is done, shouldn't I be able to still print, with black. And why it would not work if only one cartridge is in.
  • HP Master
  • 1,121 Answers
My dear its business, printers are running with mono cartridge,with our color cartridge who will buy color one? Its story of razor and blade, once you purchased razor, every time you need to buy blade! if the blade cost is half of the razor cost what you will do?. You cannot throw the razor out or else you can't spend on blade..this is business...
Posted on Sep 29, 2011
6ya staff
SOURCE:
Won't print because color is out, I have setting on black only shouldn't that work?
i think all printers do not print if one of the separate color cartridges is empty. check ink and replace. hope this will help.
Apr 02, 2012 | Canon PIXMA MX310 All-In-One Printer
My color inks are out of ink but still in the printer...i just replaced the black ink. when i try to print, it will not allow me and says to replace the color inks first. i followed the instructions to...
The Lexmark Impact S305 printer requires all the cartridges to have ink in them to continue printing - even if you're printing using black ink only. To print true black, you actually use some of the color ink.
Note: Leaving the color cartridge empty or dry isn't good for the printer. It can lead to poor print quality if you want to print color in the future.
Sep 23, 2011 | Lexmark S305 IMPACT LEXS All-In-One...
Will only print yellow, black and photo black-- red cartridge shows ink in window and I just refilled blue-- cartridge was only out of printer a few hours. I've cleaned the print head a number of...
There are a few things here that will do this. One is the cartridge is a smart cartridge and unless you reset the chip it either won't print or shows low. If you filled it before then this shouldn't be it. If you have refilled the cart more than a few times they sometimes just stop. This is either the ink has jelled inside or the little feeder sponge is dried out. If you changed ink brands sometimes the ink reacts with the old stuff and jells.The other is the jet or any feeder tubes are plugged with dried ink. Usually happens if you haven't printed for a while. You can try running the cleaning cycle and it will take quite a few of these sometimes before it starts working.
There are a few more tricks for cleaning such as using white vinegar to dissolve dried ink but that's a bit of the messy side sometimes. Usually we have just had to buy a replacement cartridge after spending the time on this. We eventually just got rig of our ink jets and got some of the cheaper color laser printers. Wish we had done that sooner.
Sep 01, 2011 | HP Photosmart D7560 InkJet Printer
HP LaserJet 2600N All colors are empty, but Black is brand new. It still says Replace Supplies and the light keeps flashing. Oh, and it won't print anything. So even if I want just B&W, do...
None of the cartridges can be empty if you want to print.
Even if you only want to print black, just black you need to
replace the other three cartridges.
Yes color laser printing is expensive.
Jul 14, 2011 | HP Color LaserJet 2600n Printer
I JUST NEED ORDER NUMBERS FOR ALL THE COLOR LASERJET CARTRIDGES FOR CP4525 PLS. THANKS,
You can find the user's guide here which lists all the parts and supplies. Here's the cartridge information from the manual:
  • HP Color LaserJet black print cartridge Standard black cartridge CE260A
  • HP Color LaserJet black print cartridge High-capacity black cartridge for CLJ4525 models only CE260X
  • HP Color LaserJet cyan print cartridge Cyan cartridge CE261A
  • HP Color LaserJet yellow print cartridge Yellow cartridge CE262A
  • HP Color LaserJet magenta print cartridge Magenta cartridge CE263A
You can use the HP numbers to look for original or after-market replacements.
Apr 29, 2011 | Office Equipment & Supplies
My printer keeps saying "print head is not installed. Install the print head." I only purchased black ink this time and I put it inside but it still says that there is no ink. Do I have to buy the colour...
Hello, Jordanreinha -
You will need to install a color cartridge, too.
Oddly enough, with color printers, both the black and color ink/s are used to print black. Go figure?
Best wishes.
Feb 26, 2018 | Canon PIXMA MP470 All-in-One Printer
Installing only one printer cartridge
suggest you install a color cartridge and set up the printer for color. When the color cartridge runs out of ink, you should be able to continue printing in black only.
Mar 19, 2010 | HP PSC 750 All-In-One InkJet Printer
New tri-color cartridge has a problem. I can't see what.
I have an HP Photsmart C4100 printer. I purchased remanufactured ink cartridges (both black and tri-colored) from Vivasmart. The black one works fine, but when I installed the tri-color, I got an error message that says "Print cartridge problem" The following print cartridge has a problem:
Tri-color.
And I can't print. The screen on my printer says "Remove and check color cartridge." I have done this several times and it still won't print. I have turned off the power, removed the cartridges, and unplugged the unit, but it still didn't help. Any suggestions?
Jul 21, 2009 | HP PSC 1510 All-In-One InkJet Printer
Not printing after color cartridge ran out - new black cartridge installed.
Yes, this printer has fixed printheads and must have ink in each color to prevent damage to the printheads. Even when printing black only each color is spit in the servicing area to keep the printhead unclogged.
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Jul 18, 2008 | Epson Stylus C60 InkJet Printer
Printer Issues
my hp psc 2210 after putting in new cartridge keeps saying press enter to align cartridge. it keeps repeating the same reading.
Apr 08, 2008 | HP PSC 2210 All-In-One InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
70 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
