SOURCE: the sensing light comes on ,clicks, nothing happens
the sensing light comes on, I hear a click but nothing happens.
SOURCE: Whirlpool duet electric dryerGEW 9200 L --no heat
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) - remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
NOTE: One item I failed to mention - Double check the input power for your dryer FIRST. You should have 220VAC at the receptacle and terminal block. The dryer will STILL tumble and the timer will still function with a portion of the input power missing as these circuits only require 110VAC. The heating circuits, however, require 220VAC to function. If one leg of the receptacle voltage is missing the dryer may exhibit "No Heat" like symptoms. This could also be an indication of a burned or failed power cord. Continuity checks performed with the dryer UNPLUGGED should indicate a short between the prong end of the cord and the respective lugs at the terminal block.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$#@!
SOURCE: I have model # GEW9250PW
This is a failed thermistior error code.
The machine control electronics monitors the exhaust temperature using the thermistor, and cycles the heater relay on and off to maintain the desired temperature. Begin with an empty dryer and a clean lint screen. 1. Plug in dryer or reconnect power. 2. Set the following configuration: ? Door - must be firmly closed ? Press Control On ? Press End Of Cycle Signal (Louder) ? Press Start 3. If after 60 seconds, E1 or E2 flashes in the display and the dryer shuts off, the thermistor or wire harness is either shorted or open. ? Unplug dryer or disconnect power. ? Check wire connections at the machine control electronics and thermistor. See Accessing & Removing the Electronic Assemblies, page 7, and figure 8 for thermistor location. ? If wire connections are good, remove the two wires from the thermistor and replace
the thermistor.
the part number is 8577274 you can remove the lower panel in the front to change the part.
thanks and please rate me thank you....ken
SOURCE: My whirlpool dryer GEW9250PW stopped
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
