Internal Bluetooth card, service manual link: http://support.dell.com/support/edoc....htm#wp1179838 Make sure you have the correct drivers installed for your OS and make sure that both wireless and bluetooth are enabled in the system setup. To do this, boot into the system setup by rebooting your computer and tapping on F2. On the left pane, look for Wireless (navigate using the arrow keys) then hit Enter, then navigate to bluetooth, make sure the setting is set to ENABLED (complete instructions for navigations and options selections should be illustrated on the lower portion of the setup screen). Once ENABLED, reboot into your OS and go into to control Panel open the bluetooth icon, make sure your external Bluetooth device (phone/smartphone, etc.) is set to discovery. Search for the device to see if it is detected. The Bluetooth Icon will appear in the systray (lower right corner of your desktop task bar. Right click on that icon and then select the option you need. Make sure you enter the same device code in both the laptop and the device you want the computer to connect to. Hope this helps FixYa! Leave some feedback and a testimonial if you find these instructions helpful.
boot to the BIOS (by turning your computer on the start tapping on F2) after that, on the left pane, look for wireless, (you can only navigate using the arrow keys. highlight wireless then hit Enter, after that highlight bluetooth check if its ENABLED, if it IS ENABLED, go to control Panel open the bluetooth icon, make sure that the device you are trying to hook up to the computer is on Discovery mode or the bluetooth wireless is activated, try searching for it (the device) see if it connects this time. Hit me back on the results.
The Dell QuickSet utility Wireless options can cause these issues.
There is a setting to always deactivate on battery.
Make sure this is not set up. The correct setting would be Always
active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
It is known to glitch when power is removed from the machine while the wireless is in use.
Please let us know if you have any futher questions. If this information was helpful, please take a moment to rate the solution. Thank you.
There is a setting to always deactivate on battery. Make sure this is not set up. The correct setting would be Always active on battery or Always On, or no power saving options for Wi-Fi. Depending on the version of QuickSet which you have.
hi,its easy
go in "starts" menu and then go in all programs and then go i bluetooth,
then go in wireless file transfer,after doing tht a bluetooth ikon will appear near the place where you see the clock on moniter,right click on that ikon and then select the option u want to perform.
remeber that enter same code in both the laptop and the device which you want to use like mobile.
cheers
