How to convert AVI video to ipad for mac
iPad, is Apple's new tablet computer that released on January 27,
2010. It's realy cool to experience the web, email, photos and video
with Wi-Fi iPad or Wi-Fi +3G iPad. However, iPad supported media formats
are limited, such as MP4, MOV, H.264 Video files and MP3, AAC, WAV,
AIFF audio. You can see the SPECS as follow:<br />
1. H.264 video up to 720p, 30 frames per second, Main Profile level
3.1 with AAC-LC audio up to 160 Kbps, 48kHz, stereo audio in.m4v,.mp4,
and.mov file formats;<br />
2. MPEG-4 video, up to 2.5 Mbps, 640 by 480 pixels, 30 frames per
second, Simple Profile with AAC-LC audio up to 160 Kbps, 48kHz, stereo
audio in.m4v,.mp4, and.mov file formats;<br />
3. Motion JPEG (M-JPEG) up to 35 Mbps, 1280 by 720 pixels, 30 frames
per second, audio in ulaw, PCM stereo audio in.avi file format.<br />
From above , we know that iPad only supports H.264 video and MPEG-4
video, So what should you do if you've got a lot of wonderful AVI videos
and want to watch them on your iPad ? but do not worry a software
called video to ipad converter software will help you solve this problem
, following I will show you how to convert AVI video to ipad with easy
steps.<br />
Quick guide how to <a href="http://www.ipad-converter-mac.net/guides/convert-avi-to-ipad-on-mac.html">convert avi to ipad on mac</a> compatible formats.<br />
Step 1: Launch <a href="http://www.ipad-converter-mac.net/">ipad converter for mac</a> and import AVI Videos. For windows user: <a href="http://www.videotoipadconverter.org/">ipad video converter</a>.<br />
This AVI to iPad Converter software is a suite, including DVD to iPad
Converter and iPad Video Converter, so you need to select "Video
Converter" button to Convert AVI to iPad Video format. Click "Open
Files" in the main interface to import your AVI videos into the program,
you can also drag AVI videos into the program directly. This software
supports batch conversion, so you can import multiple files at a time.<br />
Tip: AVI to iPad Converter enables you to add different video formats
and to get different output formats with only one conversion.<br />
Step 2: Customize the AVI Videos for your iPad.<br />
After you finish the setting of various effects, you can choose the
output format from the "Profile" area, click the "..." to select
iPad> iPad (*.mp4) and set the output folder by clicking the "Output"
button.<br />
Tips: If you don't want to use the default video and audio encoding
settings, you can set the Video and Audio options, for example, Video
Size, Video Bitrate, Audio Birate, Sample Rate, etc..<br />
Step 3: If you make sure that everything is Ok, you can click the "Convert" button to Convert AVI to iPad.<br />
Tips: After conversion, you can import the converted AVI video to
iPad with iTunes. Just open iTunes and click "File" to load your MP4
video into iTunes library. Now for the next moment you can enjoy your
AVI video on your ipad.<br />
