SOURCE: Leaking // bleach/fabric softener dispener isnt emptying
Stara, sounds like you have a couple of issues going on here. On the model you posted there was a service flash on the dispensor. They redesigned it to provide an additional air gap for release. There was also a flash on the bleach hose splitting and leaking. The service flash numbers are 26-747 for the despensor and 26-746 for the hose leak. It almost sounds like your transmission is not going into it's nuetral drain. After completeing the agitation, it should drain for about 90 seconds before spinning. This would be a gearcase problem. The gearcase is covered for a period of 5 years, part only. You might want to check where you bought this unit and see if the parts are covered under warranty. Including the dispensor and hose. You would have to pay the labor..Hope this info helps
SOURCE: LG WM2233H Washer
Most likely the small electric motor that moves the water injection pipe on to the various outlet mainifolds has stripped its plastic gears, afraid the only solution is a new soap dispsener assembly
SOURCE: water in washing machine from emptying sink.
A washing machine filling with water overnight or when not in use has two possible causes. Either the water is running into the washing machine from the sink ( If the drain hose is connected directly to the u-bend under the sink ) or one of the water valves isn't shutting off properly and water is dripping slowly but surely into the washing machine. The latter problem can take several hours before the water level rises high enough inside the washing machine to be visible.
It's easy to track down the cause of water entering the washing machine when not in use. If turning off the hot and cold water taps stops it, then it's one of the water valves not shutting off properly, and needs replacing. It's just a process of elimination to find out which one it is. If not, the water is likely to be coming from the sink (use above link). Sometimes by removing the soap dispenser drawer and carefully observing inside the soap dispenser you can clearly see water dripping in at regular intervals.
Blocked water valve filters: I've come across cases where a filter in the water valve has become caked in a brown sludgy mud-like substance due to disturbances in the plumbing. This could be because of work carried out on internal plumbing or even after workmen have turned the water off in the street to work on the water mains. After the water is turned back on, muddy or gritty water can enter the household pipework and when you use the washing machine it can draw this contaminated water into it.
In this scenario very fine grit or muck can get past the filter and stop it shutting off properly, or the filter is so blocked that water pressure to the valve is reduced enough to prevent the valve shutting off properly. Remove the water valve filter with some pliers and thoroughly clean it out. If the fault persists, replace the valve.
Important things to watch out for are -
Faulty water valves should be replaced or there is risk of flooding.
SOURCE: Water stays in detergent/bleach tray
There is a small piece that goes over the tray but it serves no purpose accept to tell you where the detergent, bleach & fabric softeners go..
SOURCE: bleach dispenser does not drain water
i just had the same prob i took off the top snap cover for the bleach and saw were the water goes out and it was clogged cleaned it out and it drains great again
