The click you are hearing is most likely the start slenoid making contact, however you should short the large wires @ the solenoid to make certain the starter still doesn't run, if so try tapping the starter with a hammer to shift the comutator a litle and try to start. Even if it now starts the starter will continue to give you problems so the proper fix is change the starter
if it came in the car look in glove box for code or in owners manual or go to the dealership......from phillis you will need to contact the company with the SS# and model.# sometime it is in the book that came with the radio
DISCONNECT YOUR BATTERY AND RECONNECT, THIS SHOULD RESET THE BRAIN.
ALSO...WHEN YOU TURN THE KEY, LISTEN TO HEAR IF YOU CAN HEAR THE FUEL PUMP COME ON...IF NOT, GUESS WHAT? HOPEFULLY NOT!... BUT,YOU MAY NEED TO REPLACE THE FUEL PUMP, IF YOU CAN'T HEAR IT WHEN YOU TURN THE KEY, AFTER YOU'VE RESET THE BATTERY!
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
Reset the player first. If that fails: Recovery Mode for Philips' GoGear Open the Philips Device Manager (Start à All Programs à Philips Digital Audio Player à SAXXX à Philips Device Manager) and click on the “Repair” tab.Then click on the “Repair” button to start the repair process.Most of the time, when your player is in that state, the Device Manager will not recognize that your GoGear is plugged in.If this is the case: Disconnect the player from the PC, and make sure the mp3 player is turned off. Hold in the volume + button on the mp3 player, and reconnect the player to your pc while holding in the volume + button. Continue holding the volume + for 10-15 seconds until a "Found New Hardware Wizard" pops up. It should recover your device if there isn't anything internally wrong with the player. Warning: this procedure will result in your songs being erased off the player, so they will have to be reloaded. -Tha Mp3 Doctor
