Question about Keurig B60 Coffee Maker
My keurig is leaking from bottom - Keurig B60 Coffee Maker
  • depasid727
    depasid727 Nov 03, 2019
    my buddy's friend makes $96 hourly on the internet. She has been with out artwork for five months however final month her charge emerge as $12747 really on foot on the internet for some hours. study greater on this net internet site.....
    HERE? www.self.cash61.com
    please don't copy"?" In Url Thanks
    New Friend:
  • 4 Answers
My Keurig B60 had the same issue. The water reservoir has a valve in a nipple on the bottom that slides into a clear plastic fitting within the base of the unit. Water from the reservoir is supposed to pass through the fitting and into the pump, which is also in the base. Over time, hard water deposits can build up on the nipple or the mating fitting (or both) such that a good seal is not made when the reservoir is in place and water slowly leaks out the bottom. To fix this, I removed the five screws on the bottom of the Keurig and then removed the two screws which hold the fitting in place. I gently cleaned both the clear plastic fitting and the nipple in the bottom of the reservoir with white vinegar. After rinsing both with clean water and drying both, I applied a small amount of silicon faucet grease (available at any hardware store) to both parts. I haven't had any more leaks since, although I assume I will have to repeat this operation periodically.
Posted on Aug 23, 2012
  • Martha Emmett
    Martha Emmett Apr 06, 2014
    Worked great and less than $4 for the grease (lifetime supply). Thank you!
  • Charles Fields
    Charles Fields Dec 24, 2014
    worked for me! thanks a bunch!
  • Keurig Master
  • 43,501 Answers
Here is a tip that I wrote about Keurig coffee brewers and the Keurig leaking problems
Keurig One Cup Coffee Brewer leaking
heatman101
Posted on Oct 02, 2011
  • 1 more comment
  • Cathy Dee Oct 22, 2011
    My B60 Keurig is leaking from the bottom, I tried taking it apart to get to the leak but I cant get to the middle of the machine where the leak appears to be coming from, why is your tip no longer available?
  • TERRY FRIZZELL Nov 27, 2011
    we need help with leaking problem- who knows the solution?
  • Janet Marchisio
    Janet Marchisio Jun 13, 2019
    I changed the position of the metal that holds the cup, and it isn't leaking any more.
    New Friend:
  • 18 Answers
If it leaks overnight, it's the reservoir. If it leaks during a brew cycle (check under the unit with a flashlight, or put a paper towel under it and pull out when the cycle is done), it's likely the gasket on the upper piercing needle in the basket area. Check to see if it's there, surrounding the needle. If it is, try pulling it down a bit. If it is not making contact (a common problem with solofill or my k-cup filling cups), it will leak from any gap present here. If you switch between regular k-cups and the solofill, you may need to repeat this whenever you switch cup type.
Good luck--this fixed my leak on my new B40.
Posted on Dec 27, 2012
There is a silicon rubber elbow that the water reservoir plugs into. It probably has a spit in it and allowing water to leak out. I've got a B77 with this problem. At one time I saw this part for sale on ebay but it is no longer listed nor will Keurig supply the part. Perhaps there is a sealant that will adhere to this material but I haven't found it yet. Good luck!
Posted on Jun 16, 2012
    New Friend:
I too have a water leak for my Keurig. You would think that
Keurig would have an answer to this problem, I am not very good
advertisment for them with water dripping down my counter.
Posted on Mar 12, 2013
    New Friend:
  • 3 Answers
There is a solenoid valve inside the machine (actually 2). One of them is leaking as the part is poorly designed. It can drip down on the air pump and also cause the problem that a lot of people have where once you push the brew button, nothing happens!
Posted on Nov 15, 2013
  • LINDA BOOTH
    LINDA BOOTH Sep 25, 2018
    Yes! That is happening to mine now!
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
Nice tutorial. Keep giving such more knowledge. If you face any issue with Geek Squad Tech Support then you can take the help from
https://geek-customer-care.com/
Posted on Oct 15, 2018
    New Friend:
Kuerig had no answer. Said they were sorry for any inconvenience then wanted me to buy a new one from them.
Posted on Sep 06, 2015
Anonymous
SOURCE:
How do I remove then casing from Keurig K10 manufactured in 2014 water leaks from the bottom
I have taken apart a Keurig and most items are not serviceable but remove the screws on the bottom and follow your water lines and see if one came lose or is leaking.
Dec 02, 2017 | Keurig Coffee Makers & Espresso Machines
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
My Keurig leaks from the bottom, it's a pain.
You may have water in the holder that supports the CUP. It needs to flushed as it has a limited area for maintain the overflow.
Mar 12, 2013 | Keurig Platinum B70 Coffee Maker
My keurig leaks from the bottom only when brewing coffee. Can it be fixed?
Here is a tip that I wrote about Keurigcoffee brewers and the Keurigleaking problems
Keurig OneCup Coffee Brewer leaking
heatman101
Jul 17, 2011 | Keurig B50 Coffee Maker
It is leaking water out of the vents on the bottom.
heatman101
Jul 09, 2011 | Keurig Platinum B70 Coffee Maker
Leaking from the bottom of my B70
heatman101
Jun 21, 2011 | Keurig B70 Coffee Maker
Works but water ( lots) is leaking out the bottom.
heatman101
Jun 15, 2011 | Keurig Elite B40 Coffee Maker
Coffee maker leaks from the bottom somewhere. Any suggestions?
heatman101
May 22, 2011 | Keurig B60 Coffee Maker
My Keurig Platinum B70 is leaking. When I put the water reservoir on to the coffee maker, water seeps out the bottom where the reservoir sits into...almost like the little valve in the reservoir stays...
Apr 23, 2010 | Keurig Platinum B70 Coffee Maker
Permanent Keurig filter leaks
Are you using the my k-cup with the Keurig pre-filled K-cups? If so it won't work. There must be a needle on the top and bottom of the K-cup for this machine to work. The My personal K-cup does not have a needle in the bottom. It's only to be used for filling with your own coffee.
Sep 17, 2009 | Keurig B70 Coffee Maker
Keurig B60 Coffee Maker Logo
62,685 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Clayton McCune
Clayton McCune
Lisa
Lisa
Pierre Laplante
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
