Hi you can use codes to unlock the mobile you can get the codes from here
mobileunlocksolutions here they ask the following details before providing the codes they are mobile model
country and the provider to which the mobile is locked .you can get the instructions about how to use the codes in your
mobile from here mobileunlockguide here they provide the step by step process about how to use the codes
once you entered the codes in your mobile as for the instructions given your mobile get unlocked and will be free to accept all
network sim.
How to change restricttion code
Try code from service provider.........
Contact your network provider..
SOURCE: remove restricted code from nokia
When you place a new or a existing SIM card from another phone provider into your mobile phone and it asks for a Security code then :-
This phone is locked to the original mobile phone provider. You need to contact this mobile provider to ask for the unlock code (security code) for this phone. You need to provide proof of ownership etc and the phone's unique IMEI number which is located inside the phone under the battery. They use this number to generate the unlock code for your phone.
They should provide you with instructions on how to enter this code into the phone.
Once you unlock the phone, then you can insert a new SIM card in this phone or sign up with another phone provider using this phone.
You could ring the phone provider and ask for the unlock security code because you are going overseas and wish to use your phone with a prepaid SIM card from another country.
The other way to get your phone unlock is to use a phone unlocking company on the Internet, they usually charge a couple of Dollars for their services.
SOURCE: i need to know how to remove a restriction code
dear sir,
i have problume in my flash disk rio unite 130 1gb it isnot work proper.
and requaire drivers of this product please resolve my problume.
thangs.
my email id is [email protected]
SOURCE: phone is restricted, need code to open the so that
Nokia Restriction Codes are used to remove restrictions added to a Nokia phone by your original carrier so it will only work with their network. It is also known as an unlock code or an unlock password.You can get the unlock code through online..........i will suggest the website Unlock-Zone.com which is doing good service .....you can approach this website.
