There can be many reasons and i will do the best to cover everything that can happen with your washer to cause it from not draining or spinning. I will attempt to cover the basic things that can happen with washing machines.
First thing to check if your washer is not pumping or spinning is to see if the motor is running. If themotor is not runningb>then check the lid switch. When the lid gets slammed it hammers that switch and eventually will bend it or break it completely. Some washers will wash but not spin or pump, others will do nothing. This switch is located under the lid on the edge of the frame around the lid. Often there is a hole that a pin from the lid will go through and push on a lever that is the switch. Check that it is not simply bent, so that it does not trip the switch inside anymore. To change or check the switch the top will need to be raised or the front removed. Getting to it, is often harder then the replacement.
Thank You, Mike Here is also My personal Sight to Help with other problems you might have as well.
Please let me know results, Thanks Mikehttp://beta.fixya.com/users/mc1bean
