If you have already tried a different cable and it didn't work, then the issue might be with the bass drum pad itself. You can try the following steps to troubleshoot:
If none of these steps work, it may be necessary to open up the pad and check the trigger mechanism inside. If you are not comfortable doing this yourself, you can take it to a repair technician.
SOURCE: Problems with DTXpress III special bass drum pad
If you are comfortable with working on it and the warrantee is up try taking the pad apart to see if the piezo element has come loose from its mounting or if the solder joint is loose. If that isn't the problem save your settings and initialize the set according to the instructions in your manual.
SOURCE: I have an electric triggered bass drum pad, and it
Test the pad driving a different sound... If the pad is weak, the sensor probably came loose in it... They are a piezo disc usually like in older musical cards.
Some of the triggers have an adjustment pot that is very tender... ALSO there usually is a setting in the machine for sensitivity.
If this has just gone bad, it is likely the sensor came loose... repairable if one opens the pad...
SOURCE: I had just recieved a brand new DM6. Upon setup
First thing to look at is the plug you are using a TRS, that is has three connections for the SNARE drum. If you partially put a TRS cable into the jack, the Tip will touch the Ring contact instead of the Tip contact. Now notice that the SNARE has a TRS plug while the kick has only a TS.plug. Could these be mis-labeled? The SNARE is the TRS and the kick is only a two conductor. If these are correct in your unit, then the jack in the kick drum itself must be broken and further that type of failure is really hard to visualize as it would require the tip contact of the jack to be drastically bent so that the plug has to be partially out to work.
So... first verify that the KICK cable has a two wire plug that is DIFFERENT from the three wire plug used on the SNARE (the snare has two pickups, one each for the head and rimshot) Should they possibly either mis-marked the cable plugs OR put the wrong plug on the Kick cable this would be the problem.
SOURCE: I'm trying to use the pads of my Yamaha DTXplorer
Actually, ONLY TWO pins are used in the MIDI cable. The data is sent serially at a 31.25KBit rate.
You probably need to "map" the ones that aren't working into the appropriate codes to trigger the SR-18 sounds.
You need to COMPARE the codes sent from the DTX to those needed by the SR-18.
There also may be options in the DTX for type of drum kit such as "Latin" and selecting one of those may have the mapping already done.
In the literature of each device will be a list of the MIDI codes the DTX generates and those required by the SR-18.
essentially the percussion codes are NOT standardized completely between devices... but there is usually a way to "map" them to make it work.
SOURCE: My Yamaha mm6 doesn't work
There is probably a setting that is wrong. The left channel is the default for mono operation. Look in your user manual regarding "PAN" which controls the output going side to side. You MAY be "panned" clear to the right. When you plug into the left, it is the default so in spite of being panned right, they would send signal to the left IF nothing is plugged into right.
