SOURCE: Loud knocking and vibration during spin
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about that...
http://www.fixya.com/support/r3663122-washer_problems_washer_noise_when
heatman101
SOURCE: washer making loud noise and wont spin
Check and see if the inner drum is loose and floppy.if it is, it's likely the bearings have collapsed, and require replacement...If the drum feels stiff and tight, it could be that something is jammed between the inner and outer drums. Both situations could be costly...Get quotes....Good luck...Nomess
SOURCE: can the basket bearing in the back of the tub be
the reason sears doesn't show this bearing is because you need to replace the whole basket and the bearings are in there when you buy the basket,check the first 3 numbers of the model number as in a 110.xxxxxxxx will be produced by whirlpool corp as sears doesn't produce any appliance themselves,then go to that manufacturer and find their parts list and that bearing will fit a kenmore washer because its really a whirlpool front load,biut the 3 numbers before the period on the model tells you who made the machine for them
SOURCE: NOISE DURING SPIN CYCLE
You have to take the tub out, take off the rotor from the bottom of the washer, remove 4 bolts and take off the stator, take off the bearing retaining nut, then drive the 2 bearings out with a drift. I bought the bearings online for 20 bucks from a supplier (VBX). They are standard metric bearings number 6005 and 6006. I put some silicone grease on the shaft seal and drove the new bearings into place. Then reassembled, and the washer is whisper quiet.
