If you're seeing notifications that the copy of Windows
that is installed on your PC might not be genuine, or that you might be
a victim of counterfeit software, it's likely that your copy of Windows
was not properly activated or is otherwise not genuine. To fix this,
click the notification and follow the steps to either repair Windows or-if you have inadvertently obtained counterfeit software-buy genuine Windows.
If you are using Windows XP, download and install the Windows Genuine Advantage Notification Application. It will scan your operating system and will remove the annoying message if it's a legitimate copy of windows.
Run a full virus scan first. Get a few different spyware and malware detector programs and run them. Also get a registry cleaner. You probably picked up a trojan that just messes with you.
since start aug 23 2009 wenever i switch on my pc the welcum screen appears and den on it a
dialog box appears as ur copy of windows didnt pass genuine windows
validation and u may b a victim os software counterfeiting and der r 2
options "resolve now" or "resolve later".
so as i click on resolve now my screen bcums black(wallpaper) and at
the right hand corner the dialog blog consists of ur windows did not
pass genuine windows and that stuff
but i dont wanna install new software just want to get rid of tht **** pls pls pls pls help its freaking me man????
waiting for reply pl pls help????
the message is displayed because your version of windows is not genuine. here are some steps to make your windows genuine 1 . start > run > " regedit" (without the quotes of course)
2 . Go to the key:
HKEY_LOCAL_MACHINE\SOFTWARE\MICROSOFT\WindowsNT\ CurrentVersion\WPAEvents\OOBETimer
and doubleclick on it.
Then change some of the value data to ANYTHING ELSE delete some, add some letters, ..just change it! now close out regedit.
3 . Go to start > run > "%systemroot%\system32\oobe\msoobe.exe /a" (again, don't type the quotes)
4 . The activation screen will come up, click on register over telephone,>next> then click on CHANGE PRODUCT KEY, enter in this key:
JG28K-H9Q7X-BH6W4-3PDCQ-6XBFJ and give update.
(Now automatically window will return back to activate by telephone mode and ask for activation code,just ignore and exit that window it's done)
the only permanent method to remove that message is buying an original version and i do recoment that, than the steps above........
Try this program:http://www.softpedia.com/get/Tweak/Unins... and disable automatic updates: START-> CONTROL PANEL-> AUTOMATIC UPDATES -> CHOOSE THE OPTION -> Turn off automatic updates <-
