SOURCE: setup photocopier wirelessly
To change paper size setting, press the user function-->user-->drawer. In order to do network printing using network port (RJ45), u need to make sure printing kit (GM107x) is installed on your machine. It looks like an thumb driver. But u can also enable the 60 days trial periods in order to try out the network printing.
SOURCE: toshiba e-studio 232 code C970
C970:
HVT or charge corona.
Remove main charge and trans/sep. coratron units and check --- make sure wires are not broke, clean grid, clean canals of units.
Replace and part needed.
If coratron units are fine --- replace HVT ( high voltage transformer).
SOURCE: Error F120
Hello sir; The error code you display F-120 it means "data base" problem it can not be reset you have to replace either memory chip or hard drive.
SOURCE: want service manual of Toshiba photocopier model studio e-206
tradebit service manual link
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
SOURCE: toshiba e-studio 232 says c440 code
This problem is caused by the thermister in the fuser section. To reset shut macine off, then turn it on while holding down the 0 and the 8 key down for more than ten seconds then release. This is service program mode, now press 4 then 0 then 0 and then the start key, you will see a nuber in the screen, press 0 then start key this should reset that code if not the thermisters need to be replaced
