The practical answer is that you can't open the camera and use compressed air. The real answer is..."sure....open it up and grab that can of compressed air. Just don't be surprised or upset when you put the camera back together and it no longer works. But the experience will be fun." If the foreign object doesn't actually appear on the pictures, don't worry about it. All lenses have stuff and dust inside. It will move around as time passes.
The non functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck.
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Thank You for using Fixya
