Yes, you blew out components associated with the monitor sends. There are several components including an RF bypass to ground and the driver IC, IC8 and a decoupling electrolytic cap. The repair is going to be extensive as it is likely you will have to remove ALL the panel knobs and screws to free up the circuit board for repair. I have worked on several mixers and have three of the PMP5000's myself and dread removing the main board. I am going to suggest something you might consider: Many of the PMP's fail either in their power supply or one of the amps. Due to the repair cost I would consider getting a scrap PMP with this problem and swapping out the panelboard for yours. Often you can get one with blown supply or power amp for around $200 and I suspect a repair shop is going to charge at least that to repair your unit... Then you will have a spare parts bucket as well.
