Question about ViewSonic N3250W Television
The volume won't stay at the level selected. It counts itself down to 00. I hold the volume button to raise the sound but it struggles to go back to 00. The highest setting goes to 03. I have no sound.
  • ViewSonic Master
  • 12,061 Answers
Remove the TV from the power for a few minutes, and then power on, then check the volume, effectively you have reset the set. If it still will not work, check the manual for any sleep settings etc, and work through the setup again for the channels. Now if none of that works, and it isn't a remote control issue? Then unfortunately you indeed have a problem with the set and it will need to be serviced. it will most likely be a microprocessor and ambient background noise sensor or the like, this will have to be replaced. To this end get a "Quote" from a certified repairer, and go from there?
User and service and repair manual at links below....should you wish to DIY?
http://www.retrevo.com/support/Viewsonic-N3250w-TVs-manual/id/276ag810/t/2/
http://michaeljaylissner.com/archive/viewsonic/n3250w-1_sm_1a.pdf
Posted on Oct 20, 2011
6ya staff
SOURCE:
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
Volume at max and won't go down
This sounds like a common problem on these TVs. Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Aug 12, 2012 | AOC L42H861 42 in. LCD TV
Volume will not change on my trio v2 plus
In the playing music mode, press the center button one time and then hit either the button to the right to raise the volume or the button to the left to lower the volume.If you hold down the center button it gives you other options.
May 09, 2012 | Mach Speed Audio Players & Recorders
Wont go into phone mode
Assuming you've tried pulling the battery and booting it again, you could try doing a hard reset on the phone (this would erase all data on the phone), by starting up the phone while holding down the volume up button while turning the phone on, waiting until you get a white screen with 3 skateboarding androids on it, and select clear storage (use the up/down volume buttons to move the cursor, power button to select), then volume up to confirm. If the phone still won't boot up after doing that, you're going to have to take it to a store, as that boot menu is the only thing that you can get to come up if it won't boot all the way up.
Nov 10, 2011 | HTC EVO 4G Smartphone
The FDA is lock and the TV wont stay on
Hello
The lock of RCA TV can be unlocked. You must have its original remote control to do this. If you haven't one, buy a new one or just borrow it from any of your friends or relatives who own the same model RCA TV you have. To unlock it, try these methods. One amoung them will surely unlock your TV.
Most RCA and GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Sep 23, 2011 | RCA TruFlat 27F520T 27" TV
Buttkicker Gamer 2 Amplifier won't turn on, light stays orange when it should be green. used to be a struggle sometimes to get it to turn green by using the remote, now it just stays orange all the...
Your Gamer 2 Amp turns on whenever an audio signal is present on the input. The amp can have trouble tuning on if the output of the source (computer sound card, etc.) has been turned down. This can happen easily if you use amplified speakers - if you turn the sound card's volume control down - and then increase the volume at the amplified speaker - the resulting sound is the same; even though the signal has been lowered. The problem is that the output from the sound card isn't sufficient to turn on the Gamer 2 Amp.
Try turning down the external speaker volume, then bump up the sound card volume. You'll probably need to adjust the other inputs individually (Wave, Mic, CD, etc) so that none is too loud or soft. Once the input values have been set, gradually increase the output of the sound card in the control panel application etc. while decreasing the volume on the amplified speaker to maintain a comfortable level. Eventually, you'll find the correct volume level on the sound card output that will wake up the Gamer 2 Amp.
If you're still having trouble, review the manual, here. I hope this helps & good luck!
Sep 20, 2011 | ButtKicker BKA1000-4A Amplifier
Need four digit code to unlock GE model 25GT240
Hello
To unlock GE TV, you must have its original remote control.
Most GE TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each procedings until you find the one that works for you.
Jun 09, 2011 | Televison & Video
Hi, phone has been switching itself off lately when im using 3g internet or sat nav etc, would struggle to reboot till i took battery out, it would then fire up. it has just switched off again and i...
You need to perform a hard reset. Unfortunately you will lose all data you have on the device. Please remove your microSD card to salvage the files saved on there after performing the reset.
Follow these instructions:
Hard Reset
  1. Remove the battery and replace it.
  2. Press and hold the Volume Button
  3. Press and hold the Power Button until the phone powers on.
  4. You should see a simple menu showing options such as Fastbook, Recovery, Clear Storage and Simlock.
  5. Using the Volume Down button to navigate, Highlight Clear Storage
  6. Press the Power Button to select Clear Storage
  7. Confirm your decision with Volume Up for Yes. If you feel like backing out, press Volume Down.
This will return your phone to it's original, out-of-the-box condition, software-wise.
If even, after the Hard Reset your phone still reboots, contact your Customer Service department for a warranty replacement.
Jun 03, 2011 | HTC Desire Cell Phone
I am able to get in with the 5898 code to unlock the tv, it won't let me put in a new code and I still can't watch r rated movies? and when I get in to the dvd side of things it only want's 3...
Hello
Just unlock it following any one of the methods described below. Then reset it as your desire. One amoung the following methods will surely unlock your RCA and give you option to do others.
Most RCA TV sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
May 17, 2011 | RCA 20F510TD 20 in. TV/DVD Combo
I need to reset my password on my rca HD52W55
Hello
If your RCA tv has locked or you want to reset your password you can opt any one of the followinf option to unlock it without any passcode nd can reset it after.
May 06, 2011 | RCA Televison & Video
Televison & Video Logo
218 people viewed this question
Top ViewSonic Televison & Video Experts
lubomir73
Level 1 Expert
Are you a ViewSonic Televison and Video Expert? Answer questions, earn points and help others
