Ricoh Aficio 2018D All-In-One Laser Printer Logo
Posted on Sep 21, 2008
Err0r sc 541
I have a richo 2018d all in one copier machine. when I powered machine a error code genereted sc 541 what is the solution
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Oct 09, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3536
Points
9
Hi
fuser code your thermistor is bad
good luck
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
1helpful
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
15helpful
5answers
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
1helpful
Code error
Push Buttons in this order:
Yellow/clear key
7
and Hold Red/Stop key, for 5 secconds.
If this works, turn machine off/on, the code should be reset. Alltho the code may come back, when the Copier attempts to print a page. If this is the case, you need your Fusing unit Repaired.
2answers
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
11helpful
2answers
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
2answers
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
19helpful
3answers
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
