Microsoft RCA CABLE INTERNET MODEM MODLE DCM305R (11603538) Logo
Posted on Sep 21, 2008
Getting limited access connection
I have RCA CABLE INTERNET MODEM MODLE DHG535-2 broadband device and it's working fine on my laptop, My wife got a new laptop lately and now when I connect the UTB cable to her laptop she get's limited access connection, what shall I do to get internet on her machine?
Anonymous
Level 1:
Problem Solver:
  • Contributor 11 Answers
  • Posted on Sep 22, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
11
Questions
Helped
4691
Points
32
On her computer, with the USB plugged in. RIGHT click the computer icon with the yellow warning symbol. It's next to the clock in the lower right hand corner of your screen. Then select "Repair."
Just bought a used gateway laptop model#m320s3400335 and cannot get internet access through a wireless network or online at all.
SETTING UP A BROADBAND CONNECTION
First you need to decide what type of broadband and Internet service you require and these are -
1. DSL that uses your existing telephone line.
2. Cable that uses a cable service and can include a cable TV service.
3. A wireless 3G network uses the mobile/cell phone network and can be separate or combine with your cell phone account. This type of Internet connection uses an USB wireless device shaped like an USB memory stick.
Note - Combined services generally offer discount pricing and may include a modem/wireless router.
If you use a wireless router with the DSL or Cable Internet service then your laptop with a wireless card can then connect to the Internet. You can also connect to a free WiFi hot spots like McDonalds, Star Bucks, the Airport etc. using the wireless card in your laptop.
If you use the wireless 3G wireless broadband service, then you can access the Internet anywhere where your ISP has 3G wireless coverage. You need to check the service coverage area where you need Internet service.
Once you decide what type of broadband your require, then you need to check with the various Internet Service providers to see if they can offer and the cost of the various plans.
Note the download limits and the associated additional costs if you exceed the monthly download limits. Once you sign up with a Internet Service provider, their documentation will include setting up instructions and/or installation CD.
How do I log on to the internet
Who to connect wifi
I connect fine to it but cannot get to internet
This is not a trivial task but to start, I presume that your Wireless Router is connected to an ADSL or CABLE modem:
1) Make sure that you can connect to the Internet/Web directly from the ADSL/CABLE modem. 2) Once you have step 1 validated, connect your Wireless router to the ADSL/CABLE modem. 3) Ensure that you can communicate to the Wireless router and use Netgear supplied software - I suggest that you connect your PC/LAPTOP used for configuration directly via an ETHERNET cable attached to your router: 'NETGEAR's Smart Wizard™ makes the set-up of the RangeMax™ wireless router easy and hassle-free. Smart Wizard automatically detects your ISP's network settings, then walks you through each step of the installation proces' 4) When the installation is finish, try connecting to the internet via the ETHENET cable on your router. If it does not work, the FIREWALL on the ADSL/CABLE MODEM may be blocking the port and needs to be opened/disabled. 5) You can now concentrate in getting the WIFI working by first using an 'unsecured/no encrytion' connection by setting an appropriate SSID. 6) Once setp 5 is working, you SHOULD NOW SECURE your Wifi connection by using a selected encryption (such as WEP or better) and security key.
ps. you will get this 'limited access' message if anywhere in the device chains the IP addresses cannot be resolved.
I've recently moved into a new place and got the right password for the internet and it will let me connect. However, it is only with limited access for some reason and when I try to get on the internet it...
the 'gateway' for the new place changes from place to place. So, you have to call on the ISP(internet service provider) to get the new configuration done for your computer.
thanks.
Wireless router says its working laptop says no its not
Your sister was accessing the wireless access point at school which is connected to the Internet/WEB access via a router and the school's broadband service provider.
For you to access the Internet using your wireless adapter on your laptop, you need your own wireless access point and connect it to a broadband ADSL or cable modem and then connect it to an Internet Service Provider. Some Internet Service Providers (cable and ADSL) can supply a combined modem/router/wireless Access point.
If you already have a broadband modem all you need is a wireless access point/router. You only need to configure the wireless access point and your wireless adapter so they will communicate with each other. Folow the instructions in the manuals.
USB Broadband to wireless router through desktop PC
If I get you right you are useing a 3g Internet connection and have a router wich conets the 2 computers together, the problem is that you can't share the internet connection.
Without any information about the operateing systems I can tell you the idea:
First you need to disable DHCP server on the router and use static IP addresses on both PC, the IP address should be something like
PC1:
IP: 192.168.0.2
Network mask:255.255.255.0
PC2:
IP: 192.168.0.3
Network mask: 255.255.255.0
Default gateway: 192.168.0.2
In this IP configuration above PC1 has the 3g modem connected.
This was the easy part, hard part is to share the internet connection on the network, that's a little different ritual on every operateing system, try to use google to get your specific one.
However there's a much more easier way to solve all your problems if you can't make it work, but it costs money. All you need to buy is a 3G router and that will do the same thing for you what your old router did.
I did a little search for you on Australian Ebay to see what you can get.
But I'm sure you have your own cheapbfavourite source of computer hardware as well.
Hope this will help you sorting out your porblem.
Regards
Imre
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Linksys Wireless-G WRT54G Ver6
Try reconfiguring the Linksys router. Click on this link for instructions on how to configure the router with a cable Internet connection.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=4da24a60bfc84fe9ad65ce672b4b8b52_KB3686_EN_070208_v1.xml&amsstatsid=4067617
After configuring the router and if you already have an Internet connection, then connect your second computer to any numbered port of the router (port 1,2,3, or 4) and test the Internet connection.
Configure the wireless settings of the router by following the steps on this link.
http://www3.nohold.net/noHoldCust56/Prod_6/KnowledgePortal/KPScripts/amsviewer.asp?docid=2f99c35863934424a932742692a5e83b_KB4024_EN_070329_v1.xml&amsstatsid=4067626
If you want to have a wireless security for your network, you may clck on this link for instructions.
Then try connecting your wireless computer to the name of your wireless network and enter the security key (if you have created one).
Belkin wireless problem
If you are connected straight from the modem, your router will not have internet access, only if your modem is connected to the router you will be able to go online wireless. connect your modem to the router nad router to the desktop, so that you can access both wired and wireless connection
Top Microsoft Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Microsoft Tool and Hardware - Other Expert? Answer questions, earn points and help others
