SOURCE: reboot portege m200
You will need to either:
Contact Toshiba to supply a restore disc.
or
Borrow an operating system disc from someone you may know and use the Windows COA that matches yours (eg. Vista Home Basic) to reinstall Windows.
SOURCE: Toshiba Portege 3500 Win Xp Bios password - How Can I flash bios?
Go to your friend. Download and burn this cd http://www.9down.com/Hiren-s-BootCD-9-8-Keyboard-Patch-73110/
Boot your pc from it and use BIOS / CMOS Tools from it.
After that use the patch
SOURCE: boot win98
I'm assuming that you mean that the computer itself has no CD or no Floppy drive.
If there is no operationg system, and no way to actually install one, then you are out of luck.
There are external CD drives, but these normally run within Windows--although your computer may allow for their use on startup.
If your computer is new enough and you can enable legacy USB, then you could theoretically copy a Win98 install CD to the USB drive and boot from that.
If you have an operating system installed and your network is running, you can share a CD on another computer and run the setup from that computer by copying the files across the network.
SOURCE: no driver cd for my portege M200
You can download the drivers from:
http://driverscollection.com/?H=Portege%20M200&By=Toshiba
