Question about LG 37LC7D 37 in. LCD HDTV
When my PC is connected to my TV, the TV screen only shows the PC's background without the icons and other stuff.
Could anyone help me with this?
When my PC is connected to my TV, the TV screen only shows the PC's background without the icons and other stuff. Hence, I couldn't watch the stored movies in my PC to my TV.
Please help. Thanks.
I cant get window media to show movies on my tv comming from my laptop everthing else works but when trying to watch a movie just a blank screen
5 Suggested Answers
6ya staff
SOURCE:
Benimur
Louie Role
  • 6966 Answers
SOURCE: Connecting to PC
Hi Sarah, You may want to try lowering the resolution of your computer down first before connecting the 42PX5D. Since everything seems to be working except when you get to the desktop then your PC might be set to a resultion that's too high for the LG (am not 100% sure, but I think that LG's max res is 1024 X 768). Try to adjust your PC's resolution while still connected to a regular monitor, right click on any free/clear part of your desktop and click properties. Display Properties window will pop-up, click on Settings tab, adjust Screen resolution towards the left,trym lowest posiible, color quality, again lowest possible. Then hook it up to the LG. If desktop now displays in LG, do the same again but this time going up. Do it by increment and stop when LG screen goes blank. Press escape to go to setting prior to blank. Adjust color quality best setting acceptable to the LG. Good luck and hopes this work out for you. Regards.
Posted on Apr 14, 2007
Anonymous
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
Anonymous
SOURCE: Trying to connect an ipod to LG plasma tv via USB
Hey - I'm in the same boat, did you get it working? I connect and get the USB menu up, but the tv says that the file is corrupt, even though the iPod works fine when it's not connected to the tv.
Posted on Jan 21, 2010
Narseman
  • 1082 Answers
SOURCE: i conneted my dell personal
It maybe that the resolution and /or the frequency (Hz) on you pc is not supported by the tv.
Supported resolutions.
  • Supported computer resolutions 640 x 350,
    720 x 400,
    1360 x 768,
    1920 x 1080,
    640 x 480 (VGA),
    1024 x 768 (XGA),
    800 x 600 (SVGA),
    1280 x 768 (WXGA),
    1280 x 1024 (SXGA),
    1600 x 1200 (UXGA)
Or you should use the HDMI connector which is reported to work well..
Posted on Nov 13, 2010
Laptop LCD/Display Problem, Green and Pink Tints???
Their are a couple things that could be causing this, My first thought is that the screen its self is damage. A LCD screen is composed of millions of tiny pixels so when some fails others will still work.
That other thought is that the GPU or video device on the laptop could be failing and creating video problems. Have you tried closing the laptop and opening it agian, this would help rule out a bad cable connection.
Dec 24, 2013 | Computers & Internet
Wi fi is appearing to other devices
I have a finlux 42" 3d tv. My pc is connected but it only shows the background picture and not the icons or start bar? how do i fix this please? thank you.
Oct 29, 2012 | Sony Vaio FZ31M Notebook
HP pavillion dv9000 has black horizontal lines across screen and looks like a snowy background
Sounds like the screen is going bad. Isolate the problem by plugging an external monitor to the laptop. Borrow a monitor from a neighbor, friend, relative or co-worker to plug to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the Borrowed monitor does not show the black lines and snowy background, that proves your video card is ok and the problem is your lcd screen. If the borrowed monitor shows the same black lines ans snowy background it means your video card inside the computer has the issue.
The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 18, 2012 | HP Compaq Business Notebook nx7000
How do i run my computer to my tv. I hooked it up through HDMI and it shows my background but nothing else.
Your monitor and your TV are currently screen 1 and screen 2 with screen 2 as an extension of screen 1 (you can move your mouse all the way across and see it come over to the TV screen). With Vista or Windows 7, right click on the desktop (no icons or programs) and choose Screen Resolution. There you will find options to change your screen output. (The choices are fairly straight forward - both screens identical, screen 1 or screen 2.) For XP, the right click on the desktop will get you to the point but I think it was called Display Options.
I hope this helps.
Apr 04, 2010 | Gateway Computers & Internet
Vostro 1510 vga to tv vga desktop picture no icons on tv
It's likely that your OS, whatever that is, wrongly identified the display size of your TV and it set the screen resolution too high, and you may even have what is known as a "virtual" desktop that is bigger than the physical screen size.
To ensure this is the case, move the mouse pointer towards the edges of the TV screen and see if your desktop scrolls along, and your icons and other stuff shows up. If this is the case, then adjust your resolution to a smaller size, say, from 1920 x 1200 to 1024 x 768, click Apply and then Ok.
That should fix the problem temporarily, but there's no guarantee that it will not do the same thing next time you connect your pc to your TV set. I have experienced the same thing with my laptop and HDTV, and I have had to repeat the process again.
Aug 17, 2009 | Dell Vostro 1510 Motherboard System Board...
Unable to connect dell precision m50 to tv monitor
Go to Control Panel - Display - Settings - Advance - Monitor Tab change Monitor Type to Generic Television click Apply
Apr 10, 2009 | Dell Precision M50 Notebook
Connecting Laptop to LCD
VGA cable doesn't carry any audio: use your audio output from PC into TV audio Input (standard RCA).
You need to configure your Display Properties to manage TV screen to get an effective connection.
Either you have a generic Video Grafic Driver add on (I'm using Intel Graphic accelerator) on your display properties either you are using a specific (NVIDIA) driver for your video card.
To check go to CP/ Display, settings Tab and in advanced you should be able to check your choice (if you don't want to go to user manual.
You can also (in CP/ Display, Settings tab configure TV as a monitor and select your option accordingly: use screen resolution on screen # 2 not over native resolution of your VIZIO screen (1080 x 960?) and be sure to use all the parameters as TV can accept.
As soon as TV is configured as per resolution and refresh etc..
check the presentation function on your PC: it's normally a FN key showing a screen icon on key top (on my Acer travelmate is FN + F5) on aspire may be it's FN + F4.
This function key will circle between: PC mail screen -> External screen (as you configured on Display settings) -> both screen.
Jan 04, 2009 | Acer Aspire 3680 Laptop
USE LAPTOP ON TV & LAPTOP AT THE SAME TIME
dear sir
yes i can help u strongly... first of all u have to turn of laptop then connect yr laptop and tv then turn laptop on now when windows appeair. laptop screen has icon and other has plane wallpaper so now go to display propaties ( click on desktop>go to propaties>setting> now it's show's 2 monitor screen on display screen click in inditeficate... how it's show "Expand display " somthing like that just remove select earrow now click apply... if it's not worked go to advance then go to adaptor setting and find display setting and select "CLONE" it's male both laptop and tv screen as same...it's help u...:)
Thanks
please vote
jo_chinmay
Oct 06, 2008 | Toshiba P000347580 - Satellite 1400&2400...
cant use s video oout have to use vga dvi ect if your tv can take it ok to work way uw ant it like a pc desktop
Feb 02, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
I can't get my iLO-2600 to completely work as a monitor.
The TV will always show as screen number 2 because the laptop screen will be found first. I use mine as a monitor for my Desktop.. However, for the picture to show what your laptop does you have to clone your desktop. The button should be where your screen properties are located.
Mar 03, 2007 | iLO 2600 Television
LG 37LC7D 37 in. LCD HDTV Logo
Ekse
RONALD CARTER JR
