On my massey ferguson tractor 255 The clutch suddenly will not engage therefore I cannot start the tractor because the high/low shifter is stuck in low gear. How do you suggest I get it out of gear?
Did you ever figure out what the problem was with your 2615 Massey Ferguson tractor and why it was stuck in gear. I have one that is doing the same thing
check your ground to the starter, if thats ok try tapping on the outside of starter body while trying to start engine, the starter may have a dead short in it
This is easy. If you live on a farm i assume you have some mechanic abilities. the tractor needs to be split in half. I have done these tractors in as little as 4 hrs. The easy way to seperate the tractor is to sleightly jack up the middle of the tractor,put a jack stand under the front of the transmision. Now move the floor jack forward to the rear of the engine. take roughly half of the weight off of the jack stand. this will allow you to roll the front half of the tractor away from the rear once you remove the trans.bolts,hydro.lines and brake rods.
