Question about Westinghouse SK-32H540S 32 in. LCD TV
Westinghouse ld-3235 picture goes in and out connections are good stops after 30 minutes or so,only 5 wks old
    New Friend:
I have the same tv and had the same problem.
If picture appears when you slowly hit back of the tv, then the solution is quite easy.
1-There are 2 small lids on the back of the tv, open the one at the top with using a screw driver.
2- there is a connector on the top, make sure that it is connected well.
As far as I understand there is somehow a connection problem or maybe result of oxidation or something.... westinghouse ld-3235 picture goes in and out - 5_3_2012_9_06_22_pm.jpg5_westinghouse ld-3235 picture goes in and out - 5_3_2012_9_06_54_pm.jpgclass=5_3_2012_9_06_54_pm.jpg
Posted on May 03, 2012
    New Friend:
  • 23 Answers
Common problem on this model. The Wires connector are good but the solder on the green board is bad. Often cold solder joints between the metal onboard connector and surface of the daughterboard. I had gotten a order of 15 of these Dead/no Video/Intermittent video. 11 were repaired with this method.
Westinghouse 32" LD-3235 LED TV
Disconnect wires
- apply flux on metal tangs
With a small tip soldering iron
- touch each contact for a few seconds.
Do not use a large tip iron
Do not overheat the contacts
Do not use a heavy hand
Best results z
Radio Shack Silver bearing solder Catalog #: 64-035 ($6.95)
Radio Shack® Non-Spill Rosin Soldering Paste Flux, Catalog #: 64-022 ($6.95)
prices are approximate.
Posted on Nov 08, 2014
5 Suggested Answers
6ya staff
SOURCE:
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Good picture for 30 minutes then colors change!
Bad LCD controller, see sample here (note, I removed the cover off the board so you can see it): http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=ltv-32w3hd&stock=all
Be real careful when you remove the back cover, the side switch assembly is attached to the back cover, so do not yank it too hard!
Posted on Jan 04, 2010
Anonymous
  • 92 Answers
SOURCE: westinghouse 30" lcd tv has no sound no picture,but green lighton
Replace the Power Supply.
Posted on Sep 06, 2009
dave1645
Dave Naylor
  • 834 Answers
SOURCE: Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Posted on Dec 07, 2009
SOURCE: Westinghouse LCD TV SK-32H540S, 1
1 swollen Capacitors / Replace
2 blown Diodes on inverter board / on some # 508 or 908
3 bad transistors in inverter bad will appear overheated powdery coat
4 replace inverter if you cannot locate problem on it
there is a safety built into the high power back light supply and that is if too much current is drawn or light is shorted it will not burn up
or hazard high volt shock to user.
capacitors and diodes driven with power transistors
look for darkened spots on the board to identify hot transistors
puffy tops and leaky bottoms of capacitors
when you turn it on does the bottom or top of the screen show image a Milli second before the other it should be evenly the lag
is the one requiring more amperage
Posted on Aug 07, 2010
Necesito el c?digo de tv westinghouse modelo LD 3235 serie 6441y13001535
The applicable code would be in a compatible remote control.
May 04, 2017 | Westinghouse Televison & Video
Why is it that my westinghouse 32 in LEDTV model#LD-3265 just went blank on me no sound no picture but powered up properly
Do the menus work or input labels appear when you change sources?
Have you tried unplugging the power with the tv turned on, waiting a few minutes, then plugging it back in and turning it on?
Jul 14, 2014 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it
hi. the led tv turn off itseft aroun 5 minutes was complete shut off or another ?? need more data???
Jan 08, 2014 | Westinghouse LD-4655VX 46" LED TV...
Westinghouse LD-4655VX Power on fine, nice picture, but around 5 minutes turn off self it,
If the set is still under warranty, the power supply board is going bad. If not you can replace it yourself. It's not that big of a job. You can find the parts you need at www.shopjimmy.com
Westing House LD-3235 will not scan
It could be the tuner but you have a few options.
First is unplug the set and or a cable or sat box and wait a while. Plug back in to see if set/box will reboot.
Another option if you have or get a Box is get one with the audio/video output jacks on the back and connect it to the same type on the rear of your set-----Bypass the tuner and operate via that input changing channels on the box.
May 27, 2012 | Westinghouse LD-3235 32in LED 720p Flat...
Westinghouse ld-3235 led tv no picture
t con board on the back of the screen will need replacing, its the one with the wires going to it from the main av board to the screen. the chip can become damaged due to heat or even come away from the board. if its working when you bag the board it could be a lose connector or the connections that is soldered to the board have come away and will need soldering back on.
Jun 05, 2017 | Westinghouse SK-32H540S 32 in. LCD TV
I have a westinghouse lt955s. The machine is stopping while it is draining and on the display it keeps on flashing LD and the number of minutes left of the cycle. Does anyone know what LD means?
Ld = all water level lisghts flashing slowly accompanied by 5 fast beeps every 4 minutes - LID is open position
got this out of machine manual hope it helps
Oct 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
Westinghouse 27" lcd hdtv
My Wesinghouse 27" lcd hdtv jumps and vertical hold is out of control after being on 15 mins. The cable company checked the connection and it is clean. We did not damage the tv. It has been doing this since we got it. We did not get a service contract. Sometimes the screen goes black with a small rolling picture on top. Help me please. Can the maufacter still help us?
we lost all the papers when we moved.
Jan 27, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse SK-32H540S 32 in. LCD TV Logo
3,842 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
