No PC stated, it has a full name
like DV7-1234us like that, 1000s of models, cant guess any here.
what is a cover.
why not state the problem first then post a question.
keyboard died? what?
covers possible
1: screen cover. (back side is a cover, front is a bezel.
2; base top cover or bottom
3: RAM cover
4: wifi module cover.
5: HDD cover.
mine has all 5.
A New hot tub cover will help you run your hot tub at a more efficient level. Lower your energy costs as the new hot tub cover will insulate better. The question is when do you need a new hot tub cover.
The best ways to know if you need a new spa cover or hot tub cover are the following:
The hot tub cover weighs over 100 pounds.
You need more then one person to remove the hot tub cover.
The hot tub cover is ripped and torn past repair.
Faded cracked and just aesthetically ugly.
The seam in the middle is ripped past repair.
Can you fix your hot tub cover? Some things you can fix like rips and tears. You can take the cover to a local seamstress to repair. You can not fix a saturated hot tub cover, it needs to be replaced at that point. New Hot Tub Cover for the Fall and Winter
1st Side cover is front cover.The cover which you use to open to install or check toner bottle.When you close that cover and machine gives caution then it means cover is not properly closed
"OR"
The 1st side cover switch is not working properly.
There is a knob at the end of the front cover, make sure it it aligned with the switch.
Front cover Micro Switch can be dirty due to toner spilling/dropping inside the machine.Clean it and then recheck.
Pry apart the back cover by guiding the flat-head screwdriver along the separating line between the front and back covers of the iPhone. When the back cover is apart from the front cover, flip the back cover off the iPhone, but be careful because a flat cable that goes to the motherboard connects the two covers.----------------------------------------------------------------------------------- NEXIQ 125032 USB Link Plus
no it is not worth that much, you can do it yourself for about 20-40 dollars (price of the gaskets)
follow these for better instructions go to www.autozone.com and register to become a member this will give you access to their repair database there you can specify your car and get repair info.
Removal & Installation2.0L Spi Engine
Loosen the clamp and disconnect the engine air cleaner to valve cover hose from the valve cover.
Remove the two ignition wire separators from the valve cover. Position the spark plug wires aside.
Remove the three valve cover bolts and remove the valve cover and gasket.
To install:
CAUTION
Do not use abrasive grinding discs to remove gasket material; only
use manual scrapers. Do not scratch or gouge aluminum sealing surfaces
or oil leaks may occur.
NOTE
Do not use any sealer with a silicone-type gasket.
Install the three valve cover bolts and remove the valve cover and gasket.
Install the two ignition wire separators from the valve cover.
Tighten the clamp and disconnect the engine air cleaner to valve cover hose from the valve cover.
2.0L Zetec Engine
Disconnect the crankcase ventilation hose from the fitting on the valve cover.
Disconnect the wiring connector at the oil control solenoid.
Disconnect the speed control (if equipped) and the accelerator control cable.
Position aside the accelerator cable.
If equipped, disconnect the speed control cable from the bracket and position aside.
Remove the ignition wires from the spark plugs.
Remove the bolts and position the upper timing belt cover away from the valve cover.
Remove the valve cover.
Fully loosen the ten bolts.
Remove the valve cover and valve cover gasket.
Inspect the valve cover for damage. Install new cover as required.
CAUTION
Do not scratch or gouge aluminum sealing surfaces or oil leaks may occur.
Clean and inspect the sealing surfaces of the valve cover and the cylinder head. Both surfaces must be clean and flat.
To install:
The valve cover gasket and the valve cover must be installed and
the bolts tightened to specification within four minutes of sealant
application.
Apply a 0.1 inch (3mm) bead of silicone sealant in two places where the front camshaft bearing cap meets the cylinder head.
Install the valve cover.
Position the valve cover gasket.
Position the valve cover.
Tighten bolts in the sequence shown.
Fig. The proper torque sequence for the 2.0L DOHC Zetec engine
Install the upper timing belt cover bolts.
Install the ignition wires.
Connect the oil control solenoid connector.
Connect the crankcase ventilation hose.
Connect the speed control (if equipped) and the accelerator control cables.
If equipped, connect the speed control cable to the bracket.
On some watches, the cover will pry off using a very small flat-bladed screwdriver or will have screws holding the cover on. On other brands the entire cover will unscrew. Examine the edge of the back cover. If there is one small depression along the edge of the cover then the cover will pry off. If there are screws present, the cover will lift off after the screws are removed. If the cover has a raised edge with flat edges opposite one another then the cover will unscrew.
The inner cover is a flap on the inside in front of the carriage when it is at rest when the cover us open. You had to flip the inner cover down to access the ink cartridges.
Open the cover. The inner cover is in the center and need to be flipped up.
Good luck.
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
