I understand that you are having trouble with your Frigidaire Affinity dryer and the door sagging, making it difficult to close and latch the door. I suggest contacting your local authorized technician for assistance with this. They should be able to realign the door without any complications. Hope this is helpful.
Hello difow - From what you are describing the issue could be related to a damaged hinge or front panel. Consult a professional for an accurate diagnosis and to assist with the repairs.
It could be the door is coming open just enough to trigger the switch to the off position. Even though the door looks closed it could be partially open. Most likely the clips that hold the door shut are not tight enough that when the clothes hit the door it pops open a little bit. These clips are basically springs and over time they loosen up.
mybe the star button stay stuck and the dryer tinks some one is puching the star button and it will continio to run. try to open the door and it will stop and then clouse the door if the dryer star whitout pushing the star then you now the star switch is stuck. goo lock
