I'm having a problem with my E232. When I plug it in to either my laptop or desktop computer the mouse and keyboard stop working. I've tried re-installing the driver but that doesn't work. The printer was working fine until today. Any suggestions or should I be looking for a new printer.
Thanks
SOURCE: lexmark won't work with vista
Yes works with Vista but you will need to use Vista driver not XP
Rate this solution then Download here
Delete old install before reinstalling!!!!
Release Notes
Attention: To prevent issues during the installation, please uninstall all previous versions of this driver prior to installing this web package.
File Information
File Name:
cjr1200EN.exe
Version:
1.0.11.3
Released On:
MAR 05 2007 00:00:00
File Size:
42452912 KB
Products:
Lexmark X1240, Lexmark X1250, Lexmark X1270, Lexmark X1280, Lexmark X1290
Languages:
Operating Systems:
Windows Vista
Application:
n/a
Owner Name:
Lexmark
Data Stream:
Lexmark Host Based Solution, Lexmark Scan and Copy Control
Security:
Install Instructions:
SOURCE: Lexmark X1185 Not working with Vista
You might try downloading the Vista driver for your printer onto all of the computers on the network that have Vista...
http://downloads.lexmark.com/cgi-perl/downloads.cgi?ccs=229:1:0:435:0:0
Hope this helps
SOURCE: status light flashing -- no communication with the printer
Please follow the instructions given below:
1. Disconnect the USB cable and the printer power cable.
2. Please disconnect the power supply from the back of the printer.
3. Then remove the cartridges from the printer.
4. Please reconnect the power supply back and turn on the printer.
5. If lights are blinking then printer encoder strip is most likely the problem. Unplug the power from the printer. Open the front cover and move the cartridge carrier to the center. You should see a white ribbon cable, a thin plastic strip and a black belt with teeth.
6. The thin plastic strip is the encoder strip. It rides in a sensor on the back of the cartridge carrier that you will not be able to see. Reach in with the first finger of either hand and carefully strum the strip as if playing a guitar.
7. The strip will need to be lowered slightly and brought towards you slightly. Please be careful not to break the strip or your printer will not function. Once you believe the strip is set correctly, plug the power back and let us know if the lights are still blinking.
8. If you cannot repair the strip, please let us know so that we can assist you further.
Please Note: Fixing the encoder strip is a delicate procedure. During the troubleshooting, if the strip breaks, you will not be able to use the printer.
9. However, if lights are not blinking then try inserting one cartridge at a time and check if you can see any lights blinking. If light blinks with one cartridge then that cartridge is defective.
