Question about HP PSC 1610 All-In-One InkJet Printer
Hp deskjet F2100 prints one line ok, then next line it only prints the top half of the text. Printer is set to Normal if I set it best quality probem is fixed, but all text appears bold
  • HP Master
  • 1,121 Answers
Print head nozzles are clogged,go to tool box select clean print heads, do the process 2,3 times check if not resoled replace print head
Posted on Oct 12, 2011
6ya staff
SOURCE:
Hp dj 3050 print not dark enough
Have you tried changing your printer settings? It may be set to draft instead of normal.
Jan 10, 2014 | HP Deskjet 3050 Wireless All-in-One Inkjet...
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
My HP 3845 lately prints grey instead of black, in 'Normal' as well as in 'Best' modes. Any idea why this could be?
Go to Control panel
select printers
right click on your printer
select PRINTING PREFERENCES
Then on the next new window that opens up (the tab should default to PAPER/QUALITY) click on the LAST tab COLOR
Here you can see if maybe somehow your PRINT IN GRAYSCALE box is checked-uncheck it to correct your problem-click on OK at bottom to save the setting
Reply back if this does not correct it.
Hope this helps.
May 11, 2010 | HP Deskjet 3845 InkJet Printer
Printing not proper
Adjust the printing properties from normal to best.
Mar 28, 2009 | HP DeskJet 3940 InkJet Photo Printer
Hp deskjet F2100 series
how do I clear a Printer HP deskjet F2100 series.? As it doesnt come out very well.
Nov 02, 2008 | Office Equipment & Supplies
Every other line prints only bottom half of text.
I have a psc 2355 printer which only prints half of text then the next lines are ok then it repeats only printing half text. I removed my ink cartridge and wiped the ink ports with a tissue heavily moisten with water. Repeated this several times and then gently dried with a tissue. The problem was fixed!!
May 08, 2008 | HP PSC 1610v All-in-One Printer
Hp deskjet f2100 all in one will complete instalation
ok..two things
download drivers from www.hp.com
then add the printer like normal
got backup?
Feb 17, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp psc 1210 all in one
Please follow the below given instructions to resolve the issue.
Please click on Start >> Programs >> HP >> HP Director.
Click on Settings >> Print Settings >> Printer Settings.
Click on Quality Tab at top of Printer Settings Window >> Set the Paper type as " Plain Paper " .
Click on Layout Tab at top of Printer Settings Window > Set the Paper size that you are using >> Click on Apply and then on OK.
Try Printing, that should resolve the issue that you are experiencing with.
If the issue still persists, try installing alternate drivers by following the below given instructions.
Installing the Alternate drivers:
1. Right click on My Computer, select Explore and then goto Control Panel, and then select Printer and Faxes.
2. Double-click the Add Printer icon. Click Next.
3. When prompted, choose Local, and then click Next.
4. In the Manufacturers list, choose HP.
5. In the Printer list, choose the HP Deskjet 870C printer, and then click Next.
6. Choose the port as parallel port, and then click Next.
7. The printer name should be listed as HP Deskjet 870C Printer.
8. Click No when the "Do you want your Windows based programs to use this printer as your default printer?" message appears. Then click Next.
9. Click No when the "Would you like to print a test page (recommended)" message appears. Then, click Finish.
Configure the alternate printer driver
1. Right-click the HP Deskjet 870C printer icon placed in the Printers window.
2. Select the Properties menu item.
3. Select the Details or Ports tab.
4. Select the DOT4_00x (where the "x" represents any digit) port from the Print to the Following Port list.
NOTE: The All-in-One model number should appear as part of the port destination.
5. Leave the printer identified as HP Deskjet 870C printer, and click the Apply button.
6. Close the Printer Properties window.
If Deskjet 870c is not listed, you may even try with Deskjet 990c or 550c
Hope that above information will work.
Regards,
Lawrence
Jan 05, 2008 | HP PSC 1210 All-In-One InkJet Printer
ONLY TOP HALF ON BLACK LINE PRINTS, COLOR OK
I am experiencing the problem with an HP Officejet 7410xi.
Nov 27, 2007 | Apple HP DeskJet 840c InkJet Printer
HP PSC 1610 All-In-One InkJet Printer Logo
210 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
