Mr.Madden Make sure to also check the power at the terminal block there should be 110 volts on each leg.there is a picture of the thermal fuse locations in my tips area for most kenmore dryer.mamake sure to check them all.there should be a couple near the bloweer wheel housing.if you have no power at all the look for the white thermal cut off and check the continuity replace if needed
I hope this helps.I will look for any further comments.
Best of luck
Be sure all controls are set correctly and door closed.
Be sure door switch is good.
Be sure you have 220 volts at power block in dryer.
remove cover and check with voltmeter .
Check heating element with ohmmeter.
Check from heating element to heater box to see if grounded.
Check thermal fuse & thermal cut-off with ohm meter.
Check all thermastats with ohm meter.
Check centrifugal swith, in motor.
