dryer did not heat up and would shut off now it heats up but beeps all the timedryer did not heat up and would shut off now it heats up but beeps all the time
You can't post conmments that contain an email address.
need to resolve laptop brand and model.Ex .dell inspiron 3521 5 beeps means RTC Error. need to replace the CMOS Battery and check. if not working pls check south bridge is heat up.
if heat up need to use cons to set heavy load to chip and (3 coins) pls use hot gun to resold the chip.
The beep is an alarm! Something in the panel, is shorted or jammed, or ann electric heating element is not making good contact or the oven door switch is showing the door open (bad switch). Good luck...
constant beeping sound is usually a key on the keyboard that is stuck. If it is not constant, like long,short,long beeps, that may indicate a problem. Let me know it is is constant or a beep code.
Need to check the continutiy of the heating coils with the help of a multimeter.
If Ok the power to the heater in the heating cycle from the program controller is important as the controller relay/contacts can be faulty..
