Frigidaire FEF336BC Electric Kitchen Range Logo
Anonymous Posted on Oct 10, 2011
Frigidare fef336ece oven stopped working - Frigidaire FEF336BC Electric Kitchen Range
Anonymous
Level 3:
  • Master 1,531 Answers
  • Posted on Oct 10, 2011
Anonymous
Master
Level 3:
Answers
1531
Questions
0
Helped
406875
Points
4453
The first thing to do is turn off the power or pull the unit out and un plug it. Then remove the back panel.chekc the wiring to the bake element if the wiring is in good shape then remove the wires from the element and use a volt meter and check the continuity.If the is no continuity then replace the bake element.if the element is goood then you will need to replace the main electronic/clock timer.
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
1helpful
I have a frigidare oven that is flashing a code F-9 when I try and self clean it wont do it and flashes this code and I cant get it to cancel the cleaning mode out now any suggestions?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
1helpful
My frigidaire fef336ece oven quit working after I heard a pop, how would I repair this?
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
1helpful
How do I replace glass top on the stove model number FEF336ECE frigidaire?
The following link explains step-by-step how to replace a glass cooktop on a kitchen range:
http://www.fixya.com/support/r4249512-replacing_glass_cook_top
If you have questions about any of these procedures, please post back and let me know. I hope this information is helpful to you.
1helpful
The lock for self cleaning is on and i cant disengage it by hitting cancel.also the door is open,and door lock is flashing
HI. Kindly shutdown the appropriate circuit breaker for 5 minutes. This will allow the unit to reset. Once the 5 minutes are up, simply re-introduce power to the unit, and try to initiate a normal cycle. If the errors are still present, after the reset, this will confirm that the Door Lock mechanism has failed. The oven will not allow itself to operate under these circumstances. Once the door lock mechanism is replaced, the unit will return to normal operation status.
I have a Frigidare washer/dryer combo (model # FLEB8200DS0). My wife washed a heavy load and the washer stopped draining completely. Agitator works fine. Please HELP...
I'm not sure if the heavy load had anything to do with it or not. this unit has a remote pump, which means the pump doesn't run off of the main belt . It actually has a motor of it's own. Basically you would have to remove the front access panel, of course unplug from power, make sure the pump will turn. with the power off you can rotate the cooling fins on the pump motor. if it turns freely then you would have to determine if the pump motor is getting power. If it is getting power then you need to replace the motor.
5helpful
Oven will not come on
There is a oven controller on those type ovens and if you cannot get your oven to heat up but the stove top still works it is because there are on different circuits and the cotroller will cost near $350 if you have a convection oven and twice that for a service person to install!!
FMV145BC1 - Frigidare Microwave will not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dhdgh
Frigidiare electric range time bake and self cleaning
Usually f3 means a faulty oven temp. sensor. If you give me the complete model # from the sticker on the oven I can tell you for sure.
Top Frigidaire Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
