The top of the dryer needs to be removed.then you will find a couple of screws on the front of the dryer inside the cabinet that need to be removed,as well as the control head and front panel. there will be a small sliver vent access panel on the lower left side of the machine in the back that needs to remove in order to take the drum belt off the motor pulley.
once you remove the front panel then the drum can be lifted out and the bearing and hub can be replaced
SOURCE: rear bearing on drum has snapped is it repairable
The bearing shaft is bolted on the bulkhead depending on the make and model. Provide these and I can be more specific.... Eric
