Kitchenaid model ksrs25ilss02 water filter
Are you saying water is dripping out the ice dispenser or the water dispenser, a water filter would have nothing to do with this, it only filters water, it does not pump water nor does it shut it off. If water
is dripping from the ice dispenser, it is because the rubber gasket
is bad on the flap that seals after ice is dispensed. If water is dripping
from the water dispenser, it is the shut off for the water, you can put a glass under it and push for water a few times,on and off and see if this makes it stop, if not you would need to have this replaced. Any questions please post back.
I have the same problem and understand mostly that the problem is in the failure of the tray to empty the ice after freezing or partially freezing it and then over flows. This causes the plastic tray holder pieces to break around it, which then causes it to get stuck rather than turning over causing he new ice tray water to over flow.
IF OYU NEED A NEW ONE Ii HAVE oNE FOR SALE?
