I have a LG WM2016CW and after I washed a med. rug none of the lights on panel wwould not work but it did ding when I pushed the start button. so after reading other solutions one said something about checking the door switch so I tried washer n woulnd'nt work so I opened the door and pushed on the door switch and it started. thank you I hope this works for u...
SOURCE: washing machine wont start on any cylcle,
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
SOURCE: Washing machine won't stop filling the tub when I
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
SOURCE: I have a Frigidaire washer model ftf2140fs1, the
There is likely to be a problem with either the door solenoid/lock or the 'door closed' sensor requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
SOURCE: The door is jammed on my LG Intellowasher
Hi, Has all the water gone out of the machine? Try it on another spin cycle if it opens then the drain filter or pump could be blocked.
Regards Elect App
