Question about Westinghouse LTV-32w1 32 in. HD-Ready LCD Television
My Westinghouse LTV 32w6 when using an HDMI cable, the picture is off center leaving a black bar on the far left. How do I fix this? Again it is only with the HDMI input
Anonymous
SOURCE:
Anonymous
  • 317 Answers
SOURCE: Westinghouse lcd tv ltv-27w2 no picture or sound
power supply first one...second one input hdmi pcb defective..
Posted on Jun 03, 2008
Tech4lfe
Neil Frazier
  • 42 Answers
SOURCE: Westinghouse LTV-32w6 power light on, no video, no sound
One thing is to make sure the inverter board is unplugged when testing the voltages. A shorted inverter will shut down the power supply if the fuse dosen't blow first. There are fuses that don't look like fuses so they can be missed. The next thing would be to look for a connector from the main to power supply and see if there is a pin labeled power on or p.on or similar. The main board should turn this line high(5V) when you push the power button. If not you probably have a bad main board. Unless you can find good used boards they are both expensive. Around $200 for PS and $300 for main.
Posted on Jul 06, 2008
Anonymous
SOURCE: LTV-32w6 won't turn on
were on the power supply is the fuse located
Posted on Nov 13, 2008
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: I own a westinghouse LTV-32w6 HD tv. After a year
Try running it with the back open, it can be the LCD controller board is overheat, http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
Posted on Feb 11, 2010
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: after about 2 or 3 hrs my Westinghouse 32
Does it look like this? http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You may have LCD controller board overheating problem (the pictures show the board with shield removed)
Try cooling it with small fan blowing at the vents.
Posted on Mar 29, 2010
Why doesn't it stay on channel?
Gustav, Try factory reset, to get to the Setup Wizard. With the TV on press the menu button on your remote. While the menu is displayed press the 0 button four times. This should bring up a new menu with factory reset as an option.
Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.hdtvsolutions.com/pdf/27w7_32w6_37w2uMan.pdf
Westinghouse LTV 32w6 User Manual
How do you factory reset Westinghouse lcd tv AskReddit
http://www.avsforum.com/forum/166-lcd-flat-panel-displays/678671-new-offical-westinghouse-ltv-27w7-ltv-32w6-ltv-37w2-thread-87.html
Mar 12, 2016 | Westinghouse LTV32W6HD 32 in. LCD...
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
I have a Westinghouse LTV-32W6 that has worked well for us since 2006 when we bought it. Recently we noticed after watching for a few hours the brightness gets darker and darker. We have it hooked into our...
That TV is about 12 years old and is wearing out. It will cost you more to repair than purchase a new one. If you keep frying to use it this machine will eventually just quit. It will cost 50.00 just to look at it.
Sep 23, 2017 | Westinghouse Televison & Video
My Westinghouse LTV-32w6 HD has sound but no picture
You may have problem with the T-C0N board, worst case will be the main logic board, try cooling the T-CON board with electronics freeze spray to see if the problem will go away, you can get it from Radio Shack.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Jun 30, 2010 | Televison & Video
After about 2 or 3 hrs my Westinghouse 32'' LTV-32w6 screen starts to turn into line like the picture is all grainy how do i fix this problem?
Mar 28, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sound cuts out in Westinghouse LTV-32w6 HD TV
is it ran through a HDMI cable?
sometimes the source is at fault or it could be a bad hdmi cable or maybe a bad hdmi port. if your using a hdmi try plugging it into another hdmi port and see if that helps
Jan 06, 2018 | Westinghouse Televison & Video
Nov 12, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Green screen on Westinghouse tv LTV 32w6
green screen on hdmi is normally a defective hdmi cable. 1st try a different device , like a dvd player. if same problem try dif cable. if it still does not work you have a defective signal pcb otherwise known as a main pcb.
May 22, 2008 | Memorex MLT3221 32 in. LCD TV
Mar 06, 2008 | Westinghouse LTV-27w6 27 in. LCD HDTV
Westinghouse LTV-32w1 32 in. HD-Ready LCD Television Logo
70 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
