I have worked with some of these in the past that have lost the convergence memory. What a pain to reset. You would have to go to the factory settings with a code. This would allow a complete grid reset of convergence. I would NOT recommend that someone without electronic experience try this alone. This procedure is recommended only for service professionals.
SOURCE: My RCA HDTV has a blurred picture and the screen is misshaped
Your convergence circuit has most likely failed. This can be a problem with the convergence power supply, convergence amp bd. or even the deflection/power bd. I would suggest a qualified tech to determine which is te problem.
SOURCE: RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
SOURCE: blue Convergence
go to main menu , selet advance setting , after that there is another menu where u going to find a convergence ajustment , select convergence adjustment , than choise blue , than after u access to blue color press the audio boton to do the blue , if u can't muve the blue color u going to have a repair service maybe ur stk or convergence ic are bad
SOURCE: the image on the tv
sound like you have a bad hyper board.not available new..need to be rebuilt by a rebuilting company
