Press the "MENU" button on your phone's handset.
I always use LEO Privacy to block unwanted calls, this applock is very good at in doing this action. LEO Privacy Applock Hide Safe Android Apps on Google Play
I think we can be against this kind of harrassment. So I would recommend an app called LEO Privacy. It can help you add the disgusting phone numbers to blacklist to stop spam and harrassing phone calls from bad guys. Read more here:https://goo.gl/BCKwGq
LEO Privacy really works, thanks for your recommandation.
View this cool softhttp://celltrackingapps.com/keylogger/ to get even more hacking features and various security issues help
I dont see who is calling me, it doesent show the id phone numbers
SOURCE: CALLER ID ONLY SHOWS "INCOMING CALL"
have the same problem with a Panasonic KX-TG9344T phone bought from USA used in india. is it a local generated problem?
SOURCE: Uniden Cordless Phone Model DSS7855.
The handset/base keeps a record of who it’s registered to. The base
also keeps a record of how many handsets are registered to it.
Using
the de-register function on the handset deletes the handset from the
base (decrements the count) and deletes the base info from the handset.
All this requires that the base and handset can communicate with each
other.
To remove the base data from a handset when out of range
of the base, press and hold the ‘end’ button and the ‘#’ button
simultaneously until the phone beeps. It will now be de-registered from
the base.
However, the base will still have this handset in it’s record.
To
de-register all handsets from the base, remove power and the base
handset. Press and hold the ‘flash/find hs’ button while applying
power. Wait for the beep and release the button. The charge light will
now flash. Sit any handset in the cradle. When the flashing stops, all
handsets are inhibited from connecting.
However, the handset
still appears to be connected to the base unit. Pressing talk will give
an ‘Unable to connect’ message. To re-register the handsets to the
base, you have to de-register the handset first with the two button
method.
Of interest, pressing ‘*’ and ‘#’ on the handset while
reconnecting the battery is suppose to reset the handset. Doing the
same on the base unit puts you in some sort of diagnostic mode. Press
speaker to exit.
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
SOURCE: Need manual for Uniden EXA18580 cordless phone
The manual can be obtained from the Uniden website in PDF format at:
http://www.uniden.com/pdf/EXAI8580om.pdf
Testimonial: "great this was needed to know how to activate recorder from another phone .Thank you all questions are answered Rachel R."
