Husqvarna Master
- Posted on Oct 18, 2011
Re: I have husqvarna 136 that won't start. If you put gas...
Replace the fuel filter in the tank, check the fuel hose up to the carb for signs of leaking, if so replace the line, between the cylinder and the carb back plate is a rubber induction tube, make sure this has no split.
Have changed spark plug, cleaned carb, checked fuel lines and added fresh fuel mixture.
replaced carb diaphram, the piece that pumps the fuel and unkinked feul line. Runs GREAT!
Check the fuel lines again. They have a habit of cracking and preventing fuel flow. One other item, there is likely a fuel filter in the tank attached to the fuel line. It may be clogged.
